3 members (TUTS 59, Jon G, Joe H),
97
Mod | | | Forums66 Topics128,026 Posts1,055,402 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 135 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 135 | | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Nice Burb you got there Smitty..........Joe | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That is a very nice looking Burb, indeed. Those build pictures are nice too. Is that yet another GMC front clip I see in the background ? | | | | | Joined: Jun 2006 Posts: 382 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 382 | That is a nice one, Smitty!  | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | looking good looking good! | | | | | Joined: Apr 2006 Posts: 273 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 273 | I LIKE IT!!  | | | | | Joined: Jan 2005 Posts: 135 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 135 | Thanks! I wish that was an extra clip in the pic, but it is the only one i've got. The fender that I am holding up is an extra that I have. | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Good lookin Burb! What's the little bump on the forward roof? Weeds | | | | | Joined: Jan 2006 Posts: 98 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 98 |
1952 Chevy Suburban 1964 Chevy Suburban 1965 Chevy Suburban 4X4 1941 Chevy Truck 1948 Sedan Delivery 2000 K2500 Suburban 2008 K1500 Suburban
Run with the dogs or [censored] with the puppies
| | | | | Joined: Jan 2005 Posts: 135 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 135 | The hump on the roof is an air vent. It is supposed to draw fresh air into the interior while you are driving. However, it moves almost no air at all. It is coming off soon. Then I'll have to patch a 6" round hole. Thanks Weeds and Perro! Hey Weeds, My burb will never be as fine as the one you are putting together. You've got one fine truck.
| | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Smitty, thanks for the compliment but don't look too close. Weeds | | | | | Joined: May 2005 Posts: 57 'Bolter | | 'Bolter Joined: May 2005 Posts: 57 | Just a warning about patching your roof-be VERY VERY careful about applying heat to a large expanse of metal like that! I learned the hard way on my 64 doing exactly the same thing you're going to do. The roof just took on a life of its own! Good luck! Jeff in IL | | | | | Joined: Jan 2005 Posts: 135 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 135 | Hey Jsff, To tell the truth I am a little concerned about patching that hole. Thanks for the advice, I plan on being extra careful!!!! | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | dropped axle looks cool,how much drop? are you planning a power steering conversion. what rear are you using. cool burb dude! | | | | | Joined: Jan 2005 Posts: 135 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 135 | Thanks for the kind words! My axle came from Sids, it is a 3 inch drop. I measured carefully and anything over 3 would put too much below the scrub line. The stock axle is already dropped 4 inches from horizontal so adding 3 inches means a 7 inch drop, so, a 15 inch wheel is 1/2 below the line, a 16 is 1 inch. I parted out a 68 chevy van for the rear end which is a 12 bolt with a 3.72 (?) ratio. It was a 6 lug which I had drilled for the 5 on 4 3/4 pattern to match the 5 lug disc brake kit on front. It measures 61 inches amd is a greast fit. I have the parts in hand for power steering. I bought the conversion kit from the former Chevy Duty. I am keeping the stock steering shaft cut off with a bearing inserted at the bottom. A universal and shaft to connect to ps box on front of frame. | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | nice burb what kind of 6 cylinder are you running i noticed the motor is side mounted | | | | | Joined: Jan 2005 Posts: 135 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 135 | Hey John, The engine is a 250 Chevy with an Offenhauser 4 barrel manifold, mild cam, and split exhaust manifold. I used a tubular motor mount from the former Chevy Duty. Thanks for the compliment! | | | | | Joined: Apr 2004 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 72 | I really like your Burb too! I have a 52 GMC myself. I talked with Sid at one of the HAMB events last year. Realy nice guy I think. Does great work. My plan is to do a dropped axle this year too. Nice to know the 3" is the mark to meet. That is what I will do too. I just need to get the axle prepped and sent off to him. Here is a link to my Burb as it is so far. These are great old trucks!! http://community.webshots.com/user/bigsix302
52 GMC Suburban...52 Chevy 3/4 ton...49 CHevy 1/2 ton Rod...49 GMC 1/2 ton retro rod project
| | | | | Joined: Apr 2006 Posts: 273 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 273 | I like yours too!  | | | | | Joined: Jan 2005 Posts: 135 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 135 | Great Burb you've got there. You did some real nice work to bringing that body back! That engine looks super! What color is that yellow? It looks good on her. What are your plans for paint?
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Hey Jsff, To tell the truth I am a little concerned about patching that hole. Thanks for the advice, I plan on being extra careful!!!! It can be a disaster if you get the roof too hot, but you'll be fine if you... 1. ...use a heat dam, an asbestos (or it used to be anyway) and water paste that you form next to the weld and it soaks up heat before it spreads too far. 2, ...do not run a bead. Tack in 4 corners and then in between each tack 180 degrees apart. Go slow and every once in a while spray some water from a spray bottle onto the area to keep it cool. Yea, it's tedious but just about guarantees no warping. Then comes the hard part... finishing a roof :crazy: I'd leave the vent. Good luck | | | | | Joined: Jan 2005 Posts: 135 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 135 | Well leaving the vent might be some good advice! Thanks for the we,lding tips! | | | | | Joined: Jan 2005 Posts: 135 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 135 | By the way, real sweet ride you've got there. What rims are you running. The have just the right amount of dish to look fine. | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | looking good once again sid what kind of trans are you running, i put a 5 speed, i have a 4 inch dropped axle i am going to install with some 16 inch 5 lug artillery wheels, i installed a lincoln disc brake rear end 62 inches wide, a booster master that is frame mounted. and a 248 gmc 6 | | | | | Joined: Nov 2007 Posts: 31 New Guy | | New Guy Joined: Nov 2007 Posts: 31 | Weeds, I'm looking at your Sub pictures and thinking yours looks shorter than mine. Were there two lengths? Doesn't seem to make sense.... inuke '49 Suburban '49 Fleetline (2) | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Wow! that is one fine looking GMC. Answer a question for me if you can. I checked with the guys who were Chevy Duty and they don't have a 250 crossmember now. Is the one you got for the 250 or did you modify the V-8 one. Nice job and thanks for your time! | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | Roadmarks use a 54-55.1 bellhousing crossmember, a 55 chevy truck v8 bellhousing and side mount the motor you can buy them from buffillo in Washington state if you cant make them | | | | | Joined: Jan 2005 Posts: 135 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 135 | Thanks for the compliment, I used a V 8 crossmwmber modified to fit the 250. I cut it in the center andwelded a sleeve to make it fit. What John said is a better way to go. | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Smitty & John...many thanks. I hope that one day my '56 TF panel will look that good. Sachse Rod shop in Texas has a universal crossmember for biscuit mounts with 19" centers and 250 engine mounts for the same spacing. Crossmember, engine mounts, and biscuits appear to be about $110 plus shipping. That is probably how I'll do my truck. I don't mind welding, but I'd like to keep things as simple as possible. Thanks again for the replies.
It is really nice that so many folks are willing to help and pass on good information! | | |
