| | | Forums66 Topics128,062 Posts1,055,847 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 55 New Guy | | New Guy Joined: Aug 2007 Posts: 55 | The aftermkt catalogs list replcment taper bearing kits to swap out the orig ball bearings on my '52 3100 front end. They do not sell the bearings individually and will not divulge the numbers. I've had no luck on the I-net. Was wondering if anyone could supply the #'s for the (2) bearings and seal. thanks. Jim | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I don't have the part numbers but in addition to the bearings and seals, you'll need the inner and outer races for both sides. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | previously said to fit in threads here: Inner: 909052R MBS (Japan) Outer: 909001R MBS (Japan) Inner seal: National #6064 check measurements against the originals
Bill | | | | | Joined: Aug 2007 Posts: 55 New Guy | | New Guy Joined: Aug 2007 Posts: 55 | Yeah,I sorta meant bearing kit complete w/races, but I didn't say that did I? Waldo, great pics on the website! Is the color the "standard" Forester Green or the "Juniper"?
Bill, thanks for the numbers! they almost co-incide with the original New Departure #'s I hope they check out. I checked out your pics also, brought back some memories. In a previous life as a fireman in a large Neastern city, local scrap yards would bring these type vehicles to our training grounds so we could play with our toys n torches, If we only knew!!! thanks again fellas. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | tools94 - Can you pass the New Departure number on us? It would be appreciated! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | New Departure Front Inner Bearing #s
1946-1953 passenger car and 1/2 ton truck, 1941-1942 passenger & commercial
909552 Outer Race 909602 Inner Race 909702 Inner Bearing
New Departure Front Outer Bearing #s
1946-1953 Passenger and 1/2 ton, 1929-1930 All, 1931-1942 Passenger & Commercial (exc. CC, DC, EC, FC Models)
909501 Inner Race 909601 Outer Race 909701 Outer Bearing
Wheel Seal Original #s for the Inners for 1946-1953 Passenger and 1/2 ton trucks with Felt seals and Retainers;
GM part # 3656536
Hope that helps, Jeff
| | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | you can also just take the race and bearing with you and match it up at the bearing place or parts store | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | So what your are saying, rustednuts, is that the bearings changed in 54 to another application. I always thought the that car and truck spindles were the same from 49 to 55.1, making the bearings the same. H-m-m-m. Learn something every day.
Joe :crazy:
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I didnt say that. I used my master parts manual which only covers 1929-1953. 1954-1959 is probably the same bearing.
Jeff | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, the spindles are the same to 59 at least
Bill | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Aren,t those New Departure #s ball brgs.? They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes they are wrencher, otherwise known as B01 and B52 ... the ones I listed above are the only thing anyone's come up with here for rollers - although the bearing shop I checked with shows them different dimensions than the original ball bearings
Bill | | | | | Joined: Nov 2006 Posts: 37 New Guy | | New Guy Joined: Nov 2006 Posts: 37 | I have the # to the lucky golden ticket.
Inner: 909052R Outer: 909067R Seal: Nationl 6064
I ordered from Jim Carter's when they had their 25% off sale and they just came in. It appears that they ordered them from Classic Performance Products.
Thanks and I hope that you find this helpful.
Kent S Butler '56 Chevy 3100 Houston, TX
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | hey! it does help, roadmarks, and interestingly it confirms what local bearing suppliers have told me, there is no exact roller replacement for the B01 and B52 [or B40] ball bearings comparison [roller specs from MBS site, ball specs from RockAuto]: inner: 909052R - bore=32.550mm - outer dia.=72.260mm - outer race width=19.00mm inner: B40[Ball] - bore=31.760mm - outer dia.=65.1256mm - width=19.2786mm outer: 909001R - bore=19.057mm - outer dia.=52.832mm - outer race width=14.00mm outer: 909067R - bore=19.057mm - outer dia.=52.832mm - outer race width:13.00mm outer B01 [ball] - bore=19.044mm - outer dia.=52.8447mm - width=18.1102mm lets you guys choose if you wanna make the change - with stock brakes and correct tire size, I decided there was no reason to "upgrade" something that's proved perfectly functional for 50 years  Bill | | |
