1 members (baldeagle), 91 guests, and 5 robots.
Topics128,014
Posts1,055,327
Members48,419
#358269 01/09/2008 2:53 AM
I'm turning into a huge fan of KROIL , that penetrating oil that's famous for freeing up stuck nuts and bolts. Today I wanted to pull the aged and cracked glass out of my new old vent windows and didn't have any brake cleaner to soften the adhesive so I sprayed some Kroil around the edges and it softened that 55+ year old stuff up and the glass came out with little effort. This stuff is great.
If you don't got some, git some.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Good stuff. Also check out www.getgibbs.com
This stuff is also amazing.
Worked at the plant for 15 years and Kroil was all the maintenance guys would use. I myself have used it for at least 15 years. To ME it is the best although I have heard good things about Gibbs. Both are cheap but I think Gibbs is higher.
Yea,Kroil it !!! Buy it by the gallon can and use it in a squirt can(oil can).It seems to last longer then the spray cans.
www.kroiloil.com
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
I have a couple of cans of PB Blaster. I like the label. Whoever designed it didn't know when to quit.
"Happiness equals reality minus expectations" - Tom Magliozzi
Used Kroil on my window regulators, one which was literaly frozen up, would not budge. Soaked it with Kroil overnite, and it freed up, used more and soaked for a few hours, and it moves like new again. Always use in on bolts before removing!
I to have used Kroil for a couple of decades and on this 1950, 3600 that I'm working on now have not had one single bolt or screw that I couldn't get loose or that has busted. I also have Liquid Wrench and PB Blaster but I still stand by my Kroil. Like the logo says, "Don't Spoil it Kroil it!"
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Kroil is the s**t!
First I ever used it was in the factory where I worked for 15 years. One of the maintenance guys left a can on my machine after a repair job, he never got it back LOL. I've been sold on it ever since! Kroil that is LOL.
Kroil is the best there is, but you do have to lube parts after you free them with Kroil, unless you use one of the other Kroil products with a added lube. The Kroil folks are great to deal with! Gibbs and WD-40 may be fine for screen door hinges, but nothing works like Kroil on stuck metal mechanisms! I got my first can almost 20 years ago from a power plant mechanic.
Les
Sounds like Kroil is pretty good stuff. Where do you buy it at?
dale937 #435013 07/22/2008 10:42 PM
Woody
Door Art Collection
Moderated by  MNSmith
