| | | Forums66 Topics128,021 Posts1,055,346 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 224 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 224 | 65 c-10 swb. i want to upgrade from my standard 3 speed manual transmission to the fully synchronized saginaw 3 speed used in the 67-72 c-10s. i know the tranny is longer and some cross member as well as drive line modifications are in order.
but heres the catch....
i still want to keep the column shift setup. has this ever been attempted? is it at all possible? I know the simplest way around this type of an add on is to cut up my floor and throw in a floor shift, but thats too easy isn't it? any experience in this arena? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I see no problem with using the original column shifter. You might need some parts form the '67-'72 to hook it up if the arm/levers are different, but that shouldn't be too difficult.
Bill Burmeister | | | | | Joined: May 2003 Posts: 224 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 224 | i figured it would prolly be alright, whats got me uncertain is if the dimension/degree of the shift box of the 60-66 is the same as the 67-72 so that the shifting arms of the later would reach without any mods...did that make any sense?
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I did this in my 64. I just had to get the newer/longer shift rods and bend them to work with my truck. I got the large diameter rods, so I had to heat and bend, but it didn't take very long to get them to the point the adjusters got them right, Scott | | |
