1 members (Hotrod Lincoln), 49 guests, and 6 robots.
Topics128,021
Posts1,055,355
Members48,420
#360330 01/13/2008 10:00 PM
65 c-10 swb. i want to upgrade from my standard 3 speed manual transmission to the fully synchronized saginaw 3 speed used in the 67-72 c-10s. i know the tranny is longer and some cross member as well as drive line modifications are in order.
but heres the catch....
i still want to keep the column shift setup. has this ever been attempted? is it at all possible? I know the simplest way around this type of an add on is to cut up my floor and throw in a floor shift, but thats too easy isn't it? any experience in this arena?
I see no problem with using the original column shifter. You might need some parts form the '67-'72 to hook it up if the arm/levers are different, but that shouldn't be too difficult.
Bill Burmeister
i figured it would prolly be alright, whats got me uncertain is if the dimension/degree of the shift box of the 60-66 is the same as the 67-72 so that the shifting arms of the later would reach without any mods...did that make any sense?
I did this in my 64. I just had to get the newer/longer shift rods and bend them to work with my truck. I got the large diameter rods, so I had to heat and bend, but it didn't take very long to get them to the point the adjusters got them right,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
