1 members (Bucker),
144
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Are the front and rear Huck-style brake drums the same? If not what is the difference? | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | No, they are not the same. All you have to do is look at them to see the big difference. And they are very hard, if not impossible, to find. So do not have the drums turned, you need to keep all the metal you can. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I found that one of the aftermarket companies have them at $95 per but wonder where they are made. I know that Bendix drums are readily available from both the USA and China. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Regarding the aftermarket drums, the supplier told me they are made in Argentina. Strange knowing that aftermarket parts come from there. Never knew that. | | | | | Joined: Mar 2007 Posts: 22 New Guy | | New Guy Joined: Mar 2007 Posts: 22 | which company carries the aftermarket huck drums? | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Carters has them up to 1 1/2 ton (or did last I checked)
American Classic has them up to a 1/2 ton. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | The Filling Station is where I found them. | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Well, I did not know they were being reproduced now. I wonder how good they are, since most repop stuff is trash. | | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | Speaking of Huck brakes, they are also on my '46. I've serviced the front ones already installing new wheel cylinder kits for both, basically cleaning the brake system up and repacking the wheel bearings. The shoes and drums themsleves were in good condition. My questions surround the rear brakes which I'm working on next. For those who have worked on these rear brakes, is there anything I need to really pay close attention to due to the fact that they are set up different than the front brakes? Is the parking brake mechanism tricky to deal with? Any tips would be helpful.
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Clean and lube the heck out of the e-brake levers and the adjusting bolts in the backing plates and the cups that fit on the wheel cylinders. When adjusting the Hucks, adjust each side up tight until the drum can't be turned at all, then back off until light scraping of the shoes are heard. Do this for each shoe. If not properly adjusted, you'll have "air in the brakes" type of symptoms that bleeding will not fix. Make sure you install a fresh grease seal on the drums too. It's no fun to redo brakes just to have them ruined by gear lube. Scott | | | | | Joined: Jan 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 56 | I'm new to the board and new to building my truck, fixing the brakes is one of the first fixes. Thanks for the the tips on where to find the brakes. I recently found pretty much all the parts I'm going to need for my 54 Chevy brakes at rockauto.com and they seem to be pretty cheap too.
RockAuto might not be the place to go for advice, but if you know the part you need, they seem to have a lot of the old truck parts.
| | | | | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | v8tvfarmgirl, Welcome to the Bolt! What part of S.IL are you from?
Blue 50
1950 3100 w/57 235 Patrick’s Saginaw 4 speed and 3:55 rear end | | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | 48bigtrucks,
Thanks for the tips! Almost forgot about that grease seal! Gotta buy a pair.
Your right, don't want to redo brakes...at least for awhile.
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Jan 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 56 | 30 miles south east of St. Louis, a little farm town called Waterloo.
You can take the girl off the farm, but you can't take the animals out of her truck. Watch the build of my 1954 Chevy at www.v8tvshow.com | | | | | Joined: Nov 2000 Posts: 1,974 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,974 | v8tvfarmgirl How about some pictures of that 54 Chevy for the Gallery? And welcome from another Illinois 'bolter. Google puts me 155 miles from you in Sullivan. Do you ever get up to Fairmont City to Gateway Classic Cars? Me and a buddy like to hit that about twice a year and dream a little.
Professional Novice
| | | | | Joined: Jan 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 56 | You can see the truck on our website www.v8tvshow.com. We do video blogs pretty frequently, the one we shot tonight is of me refurbishing my brake parts with Eastwood paints. Its a major low buck build, the truck is totally for hauling parts to and from the shop. I haven't been to Gateway Classic Cars, drove by it a few times. I'm learning so much on this site. Great community and great information.
You can take the girl off the farm, but you can't take the animals out of her truck. Watch the build of my 1954 Chevy at www.v8tvshow.com | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | http://v8tvshow.com/content/view/371/85/Kelle, Nice introduction video. Why would you want to convert to 12v with a starting system that turns as fast as yours does? If you want an electronic ignition, a 6v electronic ignition is available from Pertronix. Now, if you want a 12v steereo system or air conditions, that's another matter. Yes, you need to choke it to start (after pumping the gas pedal a few times and giving it a little throttle). Each one of these old trucks has a slightly different starting ritual. Nice 54. Tim | | | | | Joined: Jan 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 56 | Thanks, We started it quickly because I slipped in a 12 volt battery just to see what it would do. I didn't have a 6 volt just sitting around. But the generator was smoking so we definately need to do the conversion. I don't need AC but I definately need a radio so the 12 volts will help. Here is the video we shot today: http://v8tvshow.com/content/view/484/1/
