1 members (Ole49GMC),
109
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I'm turning into a huge fan of KROIL , that penetrating oil that's famous for freeing up stuck nuts and bolts. Today I wanted to pull the aged and cracked glass out of my new old vent windows and didn't have any brake cleaner to soften the adhesive so I sprayed some Kroil around the edges and it softened that 55+ year old stuff up and the glass came out with little effort. This stuff is great. If you don't got some, git some. | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Good stuff. Also check out www.getgibbs.comThis stuff is also amazing. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Worked at the plant for 15 years and Kroil was all the maintenance guys would use. I myself have used it for at least 15 years. To ME it is the best although I have heard good things about Gibbs. Both are cheap but I think Gibbs is higher. | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Yea,Kroil it !!! Buy it by the gallon can and use it in a squirt can(oil can).It seems to last longer then the spray cans. www.kroiloil.com
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | I have a couple of cans of PB Blaster. I like the label. Whoever designed it didn't know when to quit.
"Happiness equals reality minus expectations" - Tom Magliozzi
| | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | Used Kroil on my window regulators, one which was literaly frozen up, would not budge. Soaked it with Kroil overnite, and it freed up, used more and soaked for a few hours, and it moves like new again. Always use in on bolts before removing! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I to have used Kroil for a couple of decades and on this 1950, 3600 that I'm working on now have not had one single bolt or screw that I couldn't get loose or that has busted. I also have Liquid Wrench and PB Blaster but I still stand by my Kroil. Like the logo says, "Don't Spoil it Kroil it!" Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | | | | | | Joined: Sep 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 191 | First I ever used it was in the factory where I worked for 15 years. One of the maintenance guys left a can on my machine after a repair job, he never got it back LOL. I've been sold on it ever since! Kroil that is LOL.
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Kroil is the best there is, but you do have to lube parts after you free them with Kroil, unless you use one of the other Kroil products with a added lube. The Kroil folks are great to deal with! Gibbs and WD-40 may be fine for screen door hinges, but nothing works like Kroil on stuck metal mechanisms! I got my first can almost 20 years ago from a power plant mechanic.
Les | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Sounds like Kroil is pretty good stuff. Where do you buy it at? | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | | | |
