1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#350633 12/20/2007 3:55 AM
http://community.webshots.com/user/smittyschevy Link to look at whats goin on with my Burb!
smittyschevy #350660 12/20/2007 5:44 AM
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Nice Burb you got there Smitty..........Joe
#350699 12/20/2007 12:56 PM
That is a very nice looking Burb, indeed. Those build pictures are nice too. Is that yet another GMC front clip I see in the background ?
1951 1 Ton Completed
truckernix #350784 12/20/2007 6:11 PM
That is a nice one, Smitty! cool
1948 Chevrolet 1-Ton Grain Truck
In the Stovebolt Gallery SOLD
More pix in Photobucket
"A Man & His Truck--It's a Beautiful Thing!"
"You're never 100% ready, you're just next"....Ty Murray
a.d.-hawk #350934 12/21/2007 2:15 AM
looking good looking good!
smittyschevy #350939 12/21/2007 2:20 AM
I LIKE IT!! smile
Old 'Burb Lover #350960 12/21/2007 3:10 AM
Thanks! I wish that was an extra clip in the pic, but it is the only one i've got. The fender that I am holding up is an extra that I have.
Old 'Burb Lover #350961 12/21/2007 3:10 AM
Good lookin Burb! What's the little bump on the forward roof? Weeds
Weeds #351240 12/22/2007 12:16 AM
looks real nice
Perro
1952 Chevy Suburban
1964 Chevy Suburban
1965 Chevy Suburban 4X4
1941 Chevy Truck
1948 Sedan Delivery
2000 K2500 Suburban
2008 K1500 Suburban
Run with the dogs or [censored] with the puppies
Perro #351259 12/22/2007 1:16 AM
The hump on the roof is an air vent. It is supposed to draw fresh air into the interior while you are driving. However, it moves almost no air at all. It is coming off soon. Then I'll have to patch a 6" round hole.
Thanks Weeds and Perro!
Hey Weeds, My burb will never be as fine as the one you are putting together. You've got one fine truck.
smittyschevy #351303 12/22/2007 3:28 AM
Smitty, thanks for the compliment but don't look too close. Weeds
smittyschevy #351308 12/22/2007 3:33 AM
Just a warning about patching your roof-be VERY VERY careful about applying heat to a large expanse of metal like that! I learned the hard way on my 64 doing exactly the same thing you're going to do. The roof just took on a life of its own! Good luck! Jeff in IL
ratskin #351552 12/22/2007 9:12 PM
Hey Jsff, To tell the truth I am a little concerned about patching that hole. Thanks for the advice, I plan on being extra careful!!!!
smittyschevy #352377 12/25/2007 7:21 AM
1 Offline
dropped axle looks cool,how much drop? are you planning a power steering conversion. what rear are you using. cool burb dude!
10 micron #352516 12/25/2007 10:10 PM
Thanks for the kind words! My axle came from Sids, it is a 3 inch drop. I measured carefully and anything over 3 would put too much below the scrub line. The stock axle is already dropped 4 inches from horizontal so adding 3 inches means a 7 inch drop, so, a 15 inch wheel is 1/2 below the line, a 16 is 1 inch.
I parted out a 68 chevy van for the rear end which is a 12 bolt with a 3.72 (?) ratio. It was a 6 lug which I had drilled for the 5 on 4 3/4 pattern to match the 5 lug disc brake kit on front. It measures 61 inches amd is a greast fit.
I have the parts in hand for power steering. I bought the conversion kit from the former Chevy Duty. I am keeping the stock steering shaft cut off with a bearing inserted at the bottom. A universal and shaft to connect to ps box on front of frame.
smittyschevy #352518 12/25/2007 10:32 PM
nice burb what kind of 6 cylinder are you running i noticed the motor is side mounted
1949 SUBURBAN
john romero #352627 12/26/2007 3:50 AM
Hey John, The engine is a 250 Chevy with an Offenhauser 4 barrel manifold, mild cam, and split exhaust manifold. I used a tubular motor mount from the former Chevy Duty. Thanks for the compliment!
smittyschevy #353936 12/29/2007 6:39 PM
I really like your Burb too! I have a 52 GMC myself. I talked with Sid at one of the HAMB events last year. Realy nice guy I think. Does great work. My plan is to do a dropped axle this year too. Nice to know the 3" is the mark to meet. That is what I will do too. I just need to get the axle prepped and sent off to him. Here is a link to my Burb as it is so far. These are great old trucks!!
http://community.webshots.com/user/bigsix302
52 GMC Suburban...52 Chevy 3/4 ton...49 CHevy 1/2 ton Rod...49 GMC 1/2 ton retro rod project
BigSix302 #353941 12/29/2007 6:58 PM
I like yours too! smile
Old 'Burb Lover #354079 12/30/2007 2:13 AM
Great Burb you've got there. You did some real nice work to bringing that body back! That engine looks super!
What color is that yellow? It looks good on her. What are your plans for paint?
smittyschevy #354137 12/30/2007 5:43 AM
It can be a disaster if you get the roof too hot, but you'll be fine if you...
1. ...use a heat dam, an asbestos (or it used to be anyway) and water paste that you form next to the weld and it soaks up heat before it spreads too far.
2, ...do not run a bead. Tack in 4 corners and then in between each tack 180 degrees apart. Go slow and every once in a while spray some water from a spray bottle onto the area to keep it cool. Yea, it's tedious but just about guarantees no warping.
Then comes the hard part... finishing a roof :crazy:
I'd leave the vent. grin
Good luck
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman #354216 12/30/2007 4:13 PM
Well leaving the vent might be some good advice! Thanks for the we,lding tips!
smittyschevy #354218 12/30/2007 4:16 PM
By the way, real sweet ride you've got there. What rims are you running. The have just the right amount of dish to look fine.
smittyschevy #354243 12/30/2007 4:59 PM
looking good once again sid what kind of trans are you running, i put a 5 speed, i have a 4 inch dropped axle i am going to install with some 16 inch 5 lug artillery wheels, i installed a lincoln disc brake rear end 62 inches wide, a booster master that is frame mounted. and a 248 gmc 6
1949 SUBURBAN
Weeds #354455 12/31/2007 3:05 AM
I
I Offline
Weeds, I'm looking at your Sub pictures and thinking yours looks shorter than mine. Were there two lengths? Doesn't seem to make sense....
inuke
'49 Suburban
'49 Fleetline (2)
1952 GMC Suburban
1949 Chevy Suburban
1949 Chevy Fleetline
Stories in the Gallery
More pix on Photobucket
inuke #367721 01/29/2008 11:53 PM
Wow! that is one fine looking GMC. Answer a question for me if you can. I checked with the guys who were Chevy Duty and they don't have a 250 crossmember now. Is the one you got for the 250 or did you modify the V-8 one. Nice job and thanks for your time!
Roadmarks #368498 01/31/2008 4:18 AM
Roadmarks use a 54-55.1 bellhousing crossmember, a 55 chevy truck v8 bellhousing and side mount the motor you can buy them from buffillo in Washington state if you cant make them
1949 SUBURBAN
john romero #369479 02/02/2008 4:27 AM
Thanks for the compliment, I used a V 8 crossmwmber modified to fit the 250. I cut it in the center andwelded a sleeve to make it fit. What John said is a better way to go.
smittyschevy #371063 02/06/2008 3:33 AM
Smitty & John...many thanks. I hope that one day my '56 TF panel will look that good. Sachse Rod shop in Texas has a universal crossmember for biscuit mounts with 19" centers and 250 engine mounts for the same spacing. Crossmember, engine mounts, and biscuits appear to be about $110 plus shipping. That is probably how I'll do my truck. I don't mind welding, but I'd like to keep things as simple as possible. Thanks again for the replies.
It is really nice that so many folks are willing to help and pass on good information!
