7 members (55shaker, KEVINSKI, TUTS 59, Otto Skorzeny, Lostbuthaulinass, 32Fordpuchoptop, moparguy),
107
Mod | | | Forums66 Topics128,141 Posts1,056,485 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Was bleeding my brakes today , i have replaced every line EXCEPT the short rubber flex hose from the frame to the rear end ...Well after pumpin an vacumin our brains out ...NO FLUID to the rear . Came to find after backtrackin the sytem till we had juice ...that that short little rubber line had completely corroded itself shut to the point of no return it would not pass a drop of break fluid. After a trip to my local NAPA , an grief of tryin to explain what i needed to the kid that might have been 17 for 10 minutes & him not bein able to help since i didnt have an exact yr. and make ..since mine is kinda pieced together..i finally asked him if he would take me too the shelf where they kept there lines an let me survey for a few minutes & he obliged . Whalla 2 minutes we had a replacement and now i got all the system bled out an workin GREAT !. Truck will be drivin to Painter monday for the cab work. WHOOHOOO !
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Common problem with rubber lines. Also have seen them act as a one-way check and keep a wheel locked once the brakes were applied. That is why it is always a good reason to change the rubber lines. I myself have gone to stainless steel from my local race supplier as the prices are the same as the rubber counterparts and they look cool to top it off.
Scott
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | SW good tech tip. I am going to use the braided stainless just in case.
~Jim
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I got rid of my rubber lines this past fall, not sure if they were the problem, but brakes worked fine afterwards. | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | One of the very first things I've done when bringing an old car home--completely rebuild the brakes: new master cylinder, rebuild or replace the wheel cylinders, any hard lines that may be thin due to rust, and always, always new rubber lines. The rest I can fix on the side of the road when it breaks! When brakes break, it becomes more of an adventure than I like.
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I had the same problem last winter with my brake lines. I had no difficulty buying the correct replacements at FLAPS. | | | | | Joined: Dec 2002 Posts: 3,442 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,442 | I've had the rubber flap inside before too... burned up two sets of shoes before i figured out what the problem was...
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Yes, I've had it do that to a front wheel, could get a very little fluid, but if you pressed the brake hard you got nothing, must have had a piece moving in there like a check valve.
Grigg | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | After having problems finding the part be sure to keep the part number so you don't have that problem in the future. I keep part nos. an all of the custom parts so I don't have problems at the parts counter. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | good tip there ttodd , just dug the box out of the burnable barrell and cut off the part # Tim | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | later trucks with disc brakes were plagued with this problem causing calipers to drag. i can remember the first one i desected, the inner hose was collapsed acting like a residual valve. pretty hard to detect just looking at hose. after 3 days i finally asked someone. | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | On the 0ther issue of the lack of knowledge behind the counter. I have an Auto Zone near me where the kid didn't know what points were. On the other hand the guy at my local Napa doesn't even need the computer to find parts for me. I tell (or show) him what I want and he goes directly to the spot and retrives it like he was waiting for me to ask for it. He even sat and figured out all the brake lines and fittings I needed for my truck and made sure I hade everything before I left. If I did it I would have been back at least twice.
A good parts man is a great find. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Tim, in looking for the same hose for rebuilding my brake system I walked in Advance Auto (I deliver parts there part time) and ask for a hose for a 1952 chev 1/2 ton pickup and the guy says "no gotta". I knew they are the same up through about 55 or 56 so I ask for one for a 54 model and wouldn't you know...they had it! I have not used it yet but if anyone wants the part # its still laying on the bench. I have mentioned this before and it may be worth repeating. Many times the same part is for MANY years. And while they have no listing for the earliest model they will many times have the parts number for the latest year model. I have done this countless times on the 37 as well as the 52. Just a thought!! | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I have mentioned this before and it may be worth repeating. Many times the same part is for MANY years. And while they have no listing for the earliest model they will many times have the parts number for the latest year model. I've done that too, to varying levels of success. Finding Brake parts for a 1946 3/4 ton is an adventure, even if you have the guy look at the 1952 parts... The book starts when they switched to Bendix from Huck. :mad: Though, I was completely shocked when my favorite FLAPS had a fuel pump for a 216 in stock... Everyone else had to order one in. | | |
