0 members (),
144
8
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I have a '46 1/2 ton and i have changed over the engine to a 235 late model. I'm trying to add a 420 4speed and am having trouble getting the brake and clutch pedals to work with it. Does anyone make a bracket to make this work easy? How about some pictures of what you may have done? Cecil............ [email protected] | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | If you find the pedals off of a 1.5 ton truck they will swap over to your 1/2 ton. The pedals mount to the bellhousing the same way and come up trough the floor the same way, but the master cylinder mounts to the frame, using a rod and clevis, and a lever and another rod and clevis to activate the master cylinder. It sounds complicated, but it gives you more room for the master cylinder... the sm420 is apretty wide transmission. It would be a good time to upgrade to a dual master at this time as well. | | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | Thanks guys. This gives me some ideas and while i was waiting for an answer, i came across a saginaw tranny. Now i really have some options. Thanks, Cecil......... | | |
