7 members (Charles in CA, Otto Skorzeny, Lonnie, 1955 1 Series, dt235sd, Wickedbass, 1 invisible), 125 guests, and 2 robots.
Topics128,081
Posts1,056,076
Members48,434
#344702 12/04/2007 9:02 PM
I have a 1965 chevy c-10 and I have no tail or brake lights. I need to know how to wire it from the fuse panel back. PLEASE HELP!!
Matt1957 #344709 12/04/2007 9:35 PM
I did have one brake light but no running lights now any ideas??
why does it always happen to me??
Matt1957 #344723 12/04/2007 10:08 PM
Check at the connector in the firewall just behind the engine, on the drivers side about exhaust manifold level. Check the ground of the taillight housings on both sides.
Matt1957 #344724 12/04/2007 10:09 PM
You should have a connector with 3 wires on the fire wall to the left of the steering column by about a foot or so were the firewall is recessed back. Check that connector on both sides and then check your grounds on the bed. There is also another 3 wire connection under the bed by the spare tire. Since the brake light was working, I'm thinking loose connection, but it could be grounds.
Larry
I don't own a vehicle that isn't old enough to drink.
LGriffin #345014 12/05/2007 3:06 PM
Your left or my left?
Builder #345279 12/06/2007 2:13 AM
It's usually a ground problem on this era truck. I run a separate ground wire right to the tail light assembly to the frame to solve most of those problems,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
