8 members (Materman, cmayna, Rusted Nut, Stovebolt48, Hugh63c10, RoadsScholar, moparguy, SNOYL),
100
Mod | | | Forums66 Topics128,070 Posts1,055,892 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 83 | So after a year or so of driving my 64 w/ 4spd I finally beefed it and tried starting the truck in gear w/out putting in the clutch. It lurched forward and I caught it immediately; no fatalities this time. But ever since I've been having a problem with the starter. About 80% of the time I go to start it, everything's in fine working order. But the other part of the time the starter will just whir around like the solenoid isn't engaging the starter gear to the flywheel. Also, regardless of the starting condition, when I let out the clutch to let the rig idle in neutral I feel a slight pull forward as though it were in gear. For the love of god, what have i done to my poor truck?!! | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | probably a burnt solenoid contact | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The starter drive is bad. It is the gear & collar assembly on the end of the starter. They are not hard to replace yourself, & a lot cheaper then getting a reman starter. On the clutch thing you may have too thick of grease in the trans. acting like a fluid coupling. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2005 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 83 | | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | What part of Mo. are you in? They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2005 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 83 | native of fredericktown, spend most of my time at school in rolla. | | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | Bluto, Wrenchbender is correct on the drive. It has small springs and rollers in it and if they become damaged it will let the drive slip. Your original drive was a 3 roller drive. I use the heavier version with 5 rollers in it. Your going to have to take the starter apart to replace the drive, now might be a good time to replace bushings, brushes etc., preventive maintenance if you will. If your interested in a very complete rebuild kit and a heavier drive shoot me an email. My kits contain lots of parts, not just your typical 3 or 4 parts like in most kits. Ken www.classicgenerator.com | | |
