3 members (Nick in Manitou, TexasA&M48Truck, Hotrod Lincoln), 191 guests, and 2 robots.
Topics128,082
Posts1,055,964
Members48,430
#343380 11/30/2007 10:02 PM
So after a year or so of driving my 64 w/ 4spd I finally beefed it and tried starting the truck in gear w/out putting in the clutch. It lurched forward and I caught it immediately; no fatalities this time. But ever since I've been having a problem with the starter. About 80% of the time I go to start it, everything's in fine working order. But the other part of the time the starter will just whir around like the solenoid isn't engaging the starter gear to the flywheel. Also, regardless of the starting condition, when I let out the clutch to let the rig idle in neutral I feel a slight pull forward as though it were in gear. For the love of god, what have i done to my poor truck?!!
probably a burnt solenoid contact
Riding in the Passing Lane
The starter drive is bad. It is the gear & collar assembly on the end of the starter. They are not hard to replace yourself, & a lot cheaper then getting a reman starter. On the clutch thing you may have too thick of grease in the trans. acting like a fluid coupling.
1972 Chevy c10 Cheyenne Super
Wow, thanks a lot guys.
What part of Mo. are you in?
native of fredericktown, spend most of my time at school in rolla.
Bluto,
Wrenchbender is correct on the drive. It has small springs and rollers in it and if they become damaged it will let the drive slip. Your original drive was a 3 roller drive. I use the heavier version with 5 rollers in it. Your going to have to take the starter apart to replace the drive, now might be a good time to replace bushings, brushes etc., preventive maintenance if you will. If your interested in a very complete rebuild kit and a heavier drive shoot me an email.
My kits contain lots of parts, not just your typical 3 or 4 parts like in most kits.
Ken
www.classicgenerator.com
