Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Wickedbass, tclederman, Youngin' Tut 59, UtahYork, Woogeroo), 37 guests, and 5 robots.
Topics128,010
Posts1,055,303
Members48,419
#342833 11/29/2007 3:01 PM
Well, I wanted to finish my engine before the end of this summer but ran out of time. it is still on the engine stand and I want to make sure it still turns when the winter is over, I know some of you guys have said to put some oil in the plug holes(correct?) Can you guys give me a brief on the best way to store this and what to do when the winter is over? Any suggestions would be most helpful.
Ed
Ed Blouch #342852 11/29/2007 3:58 PM
If you rebuilt it ,it should have oil on the rings and lube on bearings already.But it still wouldn't hurt to spray fogging oil in the cyl's and turn it over anyway.Light{30wt) oil would work also.Keep it covered with a sheet or cloth tarp.Don't use plastic as moistre can form under the plastic.
When you finish it up in spring just prime the oil systym-use a drill with a screwdriver or old dist shaft in the dist drive,install dist, fire it up.It'll smoke for a bit till the oil burn's off but it'll be ok.Tom
grub #342853 11/29/2007 4:04 PM
As Grub said ...maybe a little extra oil ...the ? is ...where ya storin it ??..if inside with a bit of regulated Temp. ..RE:HEAT would be best .
then you have NO WORRIES abought condensation ...etc ..
Tim
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #342874 11/29/2007 5:24 PM
Tim, it is going to be stored in my garage with no heat.
Thanks to all for the info.
Ed
Ed Blouch #342895 11/29/2007 6:16 PM
Cement hold moisture and it would be best to block it up off of the cememnt, or to have it on an engine stand. Oil it up and cover it with an old comforter. It will last through a winter just fine.
In the spring is when most of the condensation is going to occur. Open the garage doors on a nicer day and vent the building when you get the chance.
Builder #343073 11/30/2007 2:47 AM
Spray WD-40 in the spark plug holes and put some old spark plugs in the holes, hand tight. Spray the rockers down with WD-40 and put the valve cover on. Do not wrap it in plastic because it will build up with moisture through condensation.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
