Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 172 guests, and 1 robot.
Topics128,274
Posts1,058,433
Members48,490
#340049 11/22/2007 1:32 AM
Hi,
I bought 2 sets from HF and they are crap. I can't move the front of my truck at all on concrete with them and it's got a 235 and I weigh more than that. I could move the rear around but with more effert than I would like.
Do the more expensive sets roll easy enough for one man to move a truck around on? I'd like to stash the truck next to the garage wall during the week and move it over on weekends to work on it.
Let's here where you got dollys (dollies?) from and how well they work for you.
Thanks All
Eric
http://s1199.photobucket.com/user/sparky234/library/My%2057%20Chevy%20Stepside?sort=3&page=1
'57 Chevy 3100 (Little Red)
'81 RD350 LC - Fun, Fun, Fun
'83 GS1100E - Pocket Rocket
57_StepSide #340080 11/22/2007 3:02 AM
I got my set from Menards. I have a 63 K20 with a big block, auto trans and a transfer case to add to the wieght and can move it around pretty good. I didn't expect to just glide it around the shop but I can move it all by myself.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
48bigtrucks #340139 11/22/2007 9:02 AM
I got mine from HF there o.k. next time I would buy a better set.
James
If it was easy, everybody would be doing it.
James B #340166 11/22/2007 3:28 PM
Ex Hall Monitor
Ex Hall Monitor
It all depends on the casters. If the dollys have good casters they'll roll OK. A lot of folks here LOVE HF & I do have a few tools from there but nothing my life or livelyhood depend on.
Tiny #340482 11/23/2007 10:48 AM
I agree with Tiny ,
It is all in the casters .
I went with a set from Northern tool with the BEST composite casters .....they work great !...now they were double the price ..Go Figure.
I can do it myself with a little effort but 2 guys can move mine with NP. i have trouble movin mine myself alone more with controling the direction it wants to go but with a helper it goes smooth.
Tim
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #340586 11/23/2007 5:34 PM
Hey Scott,
You've been around the block, do ya think the ones ya got from Maynard’s are any better than the ones from HF? Other than cutting up our nice urethaned floor with a steel wheel I don’t see why the HF ones wouldn’t work all right. The cast wheels are crowned so they should roll fairly easy. I’m sure the more expensive casters have ball brgs. instead of just a drilled hole and the wheels are probably urethane also.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
The Menards dollies are a bit stronger looking with a reinforcing rod across the top of the "dip" to prevent flexing and I think are alittle bigger too. That helps with my 3/4 ton sized tires. I've never used HF dollies, just looked at them, so I can't say how well they work compared to mine. They also have the poly wheels so no floor damage from these either. Wait for a sale at Menards and you should be able to pick them up fairly reasonably. Also, I bought mine from Menards before we had a HF store in our area,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
48bigtrucks #341497 11/25/2007 7:55 PM
GoJack is the way to go if you are serious, but they are not cheap! The GJ5000 (rated at 1250 lbs.) is $309.00 per set of two and the GJ6200 (rated at 1550 lbs.)is $439.00.Check them out at www.awdirect.com
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
Moderated by  MNSmith
