3 members (dt235sd, Tom McGrath, 55shaker), 94 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#339178 11/19/2007 11:39 PM
Hello I am working on a 58 apache. I removed the gas tank to work on the cab and while the tank looks like there is no rust on the outside, I can hear some debris on the inside. Is there some way to flush the tank and refurbish the inside?
brian
briang #339184 11/19/2007 11:56 PM
Riding in the Passing Lane
Pull the sending unit & look down inside. If it is rusty it,s better to just get a new tank on a model like that. They are reasonable & readily available. The loose stuff might just be some trash that got in through the years.
1972 Chevy c10 Cheyenne Super
I agree, if they are readily available it may be easier just to buy a new one.
If you want to clean it out Id dump in a few coffee cans of old bolts and put a gallon or two of diesel in, cap her off and roll her around the yard a hundred times. Then dump and keep rinsing it out til it comes out clean. I filtered the diesel into a bucket and used a drill pump to recirculate the clean back in.
Jeff
My 1953 Chevrolet
1947.1 Gallery
rustednuts #339194 11/20/2007 12:24 AM
Red dot, center of chest ...
Your local radiator shop can clean and seal the tank for you. Or you can buy flush and seal kits from folks like POR-15. A new tank is $129.95 at LMC.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
I want to know where these radiator shops are hiding! I called every shop on our peninsula and no one would do it. I ended up finding a place in West Seattle who wanted 200$ just to clean it! That was ridiculous which is why I did it myself...
My 1953 Chevrolet
1947.1 Gallery
I just restored the tank on my '48 with POR15 products. about $60 in materials and a little time, I now have a sealed, painted, rust-free tank. I soaked the tank in a mild muriatic acid solution for a few days and pressure washed the rust off of it, then followed the POR15 instructions.
The local rad shops here clean tanks for time and materials, usually comes out to about $80
All that work...$130.00 sounds cheap...
~Jim
Apprentice
Apprentice
I was quoted, over the phone, $180.00 to $250.00 in Oakland to clean and coat a tank. I saved a lot by getting a new one. Martin
chrmc #339824 11/21/2007 3:57 PM
Ex Hall Monitor
Ex Hall Monitor
Radiator shops around here won't touch an old gas tank. If there are new tanks available (an option I didn't have) that would probably be the best route to go. If you want to save your original tank a search will turn up hours of reading on how others, including me, have done it. Good luck.
Tiny #339980 11/21/2007 9:52 PM
I,ve had them cleaned & coated at radiator shops & it winds up comeing loose makeing it worse then it was. If you have one of those see through inline filters the gas would be real red like the old Ethel gas we used to get. That was some real gasoline.
IMO - For the kind of money they get to coat a tank, if you can't find a used one that is clean, I would always elect to buy a new one.
Builder #340010 11/21/2007 10:51 PM
I just finished cleaning my tank out of my '49 Chevy that had been sitting for about 5 years. I emptied the old gas and then poured industrial strength floor cleaner in it. Then I stuck a water hose in it and let it fill up then just emptied it out. It took about three washes but now it is clean.
Matt M.
'49 Chevy 3100 5 Window (Project, started Feb 2019)
Builder #340012 11/21/2007 10:58 PM
My favorite tank cleaning method that I believe someone once posted here was gravel and acid in the tank, then strap it lengthwise against your rear tractor wheel and go about your field business. I understand it cleans them up right nice.
1950 Chevrolet 3100 Deluxe Cab
Gallery Page
Webshots photos
If you have a gas tank renu usa place near you, they do a very nice job.
I like the tractor wheel idea. I might give that a try sometime.
