4 members (SmalltownTRKGuy, Otto Skorzeny, Bill Hanlon, GrandpasJimmy), 123 guests, and 3 robots.
Topics128,194
Posts1,057,248
Members48,466
#339996 11/21/2007 10:29 PM
I am getting ready to buy a 1963 Chevy C-60 dump truck. The brake pedal has to be pumped 3-4 times to get pressure. This will stop the truck but as soon as I let off the pedal I have to pump them again.
Does anyone know what the problem is? I have a couple of theories but no experience with this truck yet.
Crimsonlake
Bleed the air out man. . .bleed them and top it off or they are way out of adjustment. . .
Mikey D
1962 GMC K3000, GMC-379 V6.
most common problem air in the system flush entire system with new fluid as this will get rid of air
7
7 Offline
I agree, probably air in the system. Brake systems seem to be one of the most neglected systems.
The best thing to do when you get an old car or truck is to flush the system. Like said before it removes the air and it also gets rid of rust and contaminates in the system.
Danny-Southeast Missouri
Thanks for the replies. There is a booster under the driver side running board. Does that need bled somehow? If so, what is the best method?
Is the booster part of the master cyl, or a seperate unit all together?
If seperate and IF the booster is functional (best way to check is to pump up the brakes as you sedcribed with the engine off, then start it up, if it's working you should feel the pedal go down a bit more as the booster comes online), there are two bleeders on the top, on at the top if the main assembly, and one at the top of the end cap where the outlet line is.
Bleeding method is from closest to furthest in relation the the master cylender, so start at the top of the booster, then the end of the booster, front wheels, rear wheels. Keep a close eye on the fluid level in the master!
I had to go through my system a couple time to get all the air out, but once you have the air out and the brake shoes adjusted properly you should be good to go.
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
Riding in the Passing Lane
I would adjust them first. They may not need bleeding.
1972 Chevy c10 Cheyenne Super
Thanks again. I will try those options.
Actually Crimson, you should be good to stop!
After learning the hard way, my advice would be to adjsut the shoes first then you can tell more about whether there is air in the lines. We ran two gallon of fluid thru our truck before realizing this.
Red meat is not bad for you.........Fuzzy green meat is bad for you!
"What happens in the garage stays in the garage!"
1958 Chevy Spartan 100 firetruck in the Gallery
Funny, but I've been taught to always bleed air from the rear wheels forward not vice versa as is indicated by Freq 2002. I guess one of us is right. That is how I've always done it and never had a single problem. It is because the fluid would displace the air and it (air)would seek the weakest, or furthest and highest level. Makes sense to me.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I believe you are mistaken. If you do this, you'll just push the air from the rear right back to the front. Bleed brakes from furthest to closest in relation to master cylinder or you'll just chase your tail all day long.
Keith
If it were easy they'd have grade schoolers doing it!
Me too.
Furthest to closest
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
chevy manuel furtherest to closest
Yanno, it doesnt really matter what method is the best one if what you do works for you. I go from what I was taught by professional mechanics, my experiences as a mechanic, and what the book says. And oddly enough, they are all pretty much the same.
But again, what works for you, works for you.
I have this to present for consideration, taken directly from the GMC 55-59, models 100-500 manual:
Page 173 describes the advised method for bleeding the brake system and refers to this bleeding sequence chart, showing what I described, only variation is it tells you to do the left wheels first, then right, and redo the booster, vs. my usual method of front, rears, then repeat whole process.
:P
Check the fluid first, Bleed the hydrovac booster & the brakes.
Check your fluid after each wheel, start on the right rear than L R -- R F -- L F Also check that there are no leaking lines or wheel cyl's.
