7 members (50Chevy3100, RdsLessTaken, DadsFirstPickup, tclederman, Cletus1950, Ponchogl, 1 invisible), 202 guests, and 3 robots.
Topics128,107
Posts1,056,225
Members48,436
#33812 04/11/2004 11:38 AM
Hi all, my uncle has a chevy 3/4 that he is letting me use for parts. Right now my 73 is 1/2 ton, I want to convert it to 3/4 ton. I know that the rear axle will bolt up fine, but what about the front end?? What all do I need to replace there, just the spindles? I dont think the coil spring is that big of a deal, or is it? The parts truck is a 74. Thanks all,
Let me know ASAP, I am going to continue working in the afternoon!
- Shane
- Shane (ChevyToughRebel)
2 Trucks;
-1955 3/4 Ton Chevy
-1979 3/4 Ton Custom Deluxe 20 4x4
1955 Second Series 3600
GED = Git Er Done
#33813 04/11/2004 4:33 PM
Isn't that one the model with the bolt-in front crossmember? It would be simpler to just swap the whoe unit, crossmember, springs, control arms, and all. Maybe I'm thinking of a later model, but on some of them, it's possible to swap the entire front suspension with about 8 or 10 bolts. I don't think the control arms, bushings, etc., are the same from 1/2 to 3/4 ton.
#33814 04/11/2004 7:41 PM
Well I hope they will come out with a few bolts like you say, does the 73 already have the holes in the frame?
- Shane
2 Trucks;
-1955 3/4 Ton Chevy
GED = Git Er Done
#33815 04/11/2004 10:07 PM
It would be easier to swap the bodies over. The frames from a 1/2 to 3/4 are different. I would think you would want the beefier frame with the heavier suspension.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#33816 04/12/2004 2:00 AM
Well, I have decided to go ahead and pull the rear axle, drive lines, and tranny and hold onto them until I get a front axle, drive line, transfer case, and suspension to convert this thing to a 4x4. So, I wont be installing any of that until then, thanks for the help guys!
- Shane
2 Trucks;
-1955 3/4 Ton Chevy
GED = Git Er Done
