9 members (crenwelge, 51sub, MickeyP, Otto Skorzeny, Thom75, TUTS 59, tclederman, JayDP, 1 invisible),
166
Mod | | | Forums66 Topics128,284 Posts1,058,531 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 19 New Guy | | New Guy Joined: Nov 2007 Posts: 19 | I'm heading to Atlanta for the weekend tomorrow to attempt cranking my grandfathers Viking 40 (not sure what year). Hasn't cranked since 1998.
The nearest parts store is 1 hour away. Any special tools, parts, or other stuff I should take with me? | | | | | Joined: Feb 2006 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 162 | A fresh battery, a small gas can and rubber fuel line (in case you need to gravity feed the carb), some electrical connectors, wire, crimpers, ect., maybe some plug wires in case rats have gotten to them, engine oil, coolant or water.
Both my big bolts (56 4400 and 59 Viking 60) had not run in 5 to 8 years, and with those items above, I got them both to run and drive, but they both still have no brakes...Good luck, be patient and have fun! Send us some picturs and let us know how you make out!
Chris
1956 Chevrolet 4400 1959 Chevrolet Viking 60 1968 Chevrolet el Camino 2002 Chevrolet 1500HD 4x4
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Don't forget some fine grit emery cloth to file the points with, Scott | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | distibutor cap, points,coil if you know which engine it has. in addition to rubber fuel hose you may consider a 3 or six gallon marine gas tank. you can tap into the fuel line prior to the fuel pump and use primer bulb to pump fuel up til fuel pump takes over. make sure line from pump to carburator is clear. good luck saw a 55.2 to 59 3100 on it's way to crusher today sad.narrow flat screw driver. battery terminal cable ends. (a lot of the older terminals the bolts are too corroded to properly clamp.)
| | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | and a partridge in a pear tree.
"Happiness equals reality minus expectations" - Tom Magliozzi
