2 members (pdlightning, Tronman), 104 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#327922 07/18/2007 2:14 AM
Apprentice
Apprentice
I was wondering if it is possible to get a key made for the orig. door lock on my '49 3100.I would really like to use the lock but I've never had the key.There appears to be a four digit number on the lock cylinder.Is this the lock code for the orig. key?Would this be something a locksmith could do or is there someone who specializes in vintage auto locks and keys?Thanks,Chip Watford
#327923 07/18/2007 3:40 AM
The ignition key must not match your door lock cylinder. If that's the case, pull the cylinder from the door and take it and your ignition key to the lock smith and have him rework it so they work together. He will also clean and lube if for you too,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#327924 07/18/2007 3:55 AM
If you get no luck locally I have had Eric Jarvison do some work for me. He has original keys. He advertize's in the VCCA magazine. If you do need to contact him let me know and I'll round up his address/number.
#327925 07/18/2007 3:57 PM
I took the special, "Authentic GM" key blanks I ordered from JC to the local locksmith so I would have a couple of extras and he said he had the same ones on the rack if I ever need more. He also said that all he needed was to see the lock cylinder to cut the new keys.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#327926 07/19/2007 12:25 AM
1 Offline
pm me with 4 digit code and i can tell you the cuts needed to make key. the correct key blank needed is a curtis B-10
#327927 07/20/2007 2:17 AM
Apprentice
Apprentice
Thanks for all the info and help.Chip
#327928 07/24/2007 12:43 AM
For what its worth...on my truck ('42 PU) there was a code stamped on the inner cylinder that the locksmith could cross-reference. He made me a new set of keys from that code.
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
