| | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 31 Apprentice | | Apprentice Joined: Oct 2006 Posts: 31 | I was wondering if it is possible to get a key made for the orig. door lock on my '49 3100.I would really like to use the lock but I've never had the key.There appears to be a four digit number on the lock cylinder.Is this the lock code for the orig. key?Would this be something a locksmith could do or is there someone who specializes in vintage auto locks and keys?Thanks,Chip Watford | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | The ignition key must not match your door lock cylinder. If that's the case, pull the cylinder from the door and take it and your ignition key to the lock smith and have him rework it so they work together. He will also clean and lube if for you too, Scott | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | If you get no luck locally I have had Eric Jarvison do some work for me. He has original keys. He advertize's in the VCCA magazine. If you do need to contact him let me know and I'll round up his address/number. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I took the special, "Authentic GM" key blanks I ordered from JC to the local locksmith so I would have a couple of extras and he said he had the same ones on the rack if I ever need more. He also said that all he needed was to see the lock cylinder to cut the new keys. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | pm me with 4 digit code and i can tell you the cuts needed to make key. the correct key blank needed is a curtis B-10 | | | | | Joined: Oct 2006 Posts: 31 Apprentice | | Apprentice Joined: Oct 2006 Posts: 31 | Thanks for all the info and help.Chip | | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | For what its worth...on my truck ('42 PU) there was a code stamped on the inner cylinder that the locksmith could cross-reference. He made me a new set of keys from that code. | | |
