3 members (KEVINSKI, Gray_Ghost, Otto Skorzeny), 113 guests, and 4 robots.
Topics128,100
Posts1,056,513
Members48,448
Is it possible to convert a door with a wing window to a door without a wing window? Next question, has anyone done it before?
Thanks for the help.
Scott
1950 Chevy 3100 5 window "in progress"
1967 Chevelle 300
Sorry, but I just realized, the year of the truck might be helpful....its a 50, but the doors must be from something newer as they have wing windows
1967 Chevelle 300
no help?
1967 Chevelle 300
50chevy....I remember asking basically that same question about a year ago as the 52 panel I drug home had a 1950 door on it. (sold it) The answer I got was that it could be done but was a big pain in the butt. I sold the door and found me two good 52 doors and moved on. Maybe someone else has actually done it and will chime in later.
thanks for the help....heres the problem I am faced with. My 50 has wing window doors on it, that are rotten at the bottoms. A while back, I got all the patch panels to make my doors nice again. In the meantime, a real nice non-wing window door has "landed" in my parts pile, with no rustout anywhere. So I dont know which direction to go.
1967 Chevelle 300
I
I Offline
Its a whole lot easier to change out the doors than to make them something they weren't. Some of the bracket inside are spot welded on and removal and replacement is going to drive you batty.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
The wingless doors are more attractive. I would use them as they came,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
