9 members (Jay R, 52Carl, 78buckshot, TooMany2count, walter74, Bill Hanlon, Barry Martak, Charles in CA, 1955 1 Series),
122
Mod | | | Forums66 Topics128,089 Posts1,056,417 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 180 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 180 | Is it possible to convert a door with a wing window to a door without a wing window? Next question, has anyone done it before? Thanks for the help. Scott
1950 Chevy 3100 5 window "in progress" 1967 Chevelle 300
| | | | | Joined: Nov 2006 Posts: 180 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 180 | Sorry, but I just realized, the year of the truck might be helpful....its a 50, but the doors must be from something newer as they have wing windows
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | 50chevy....I remember asking basically that same question about a year ago as the 52 panel I drug home had a 1950 door on it. (sold it) The answer I got was that it could be done but was a big pain in the butt. I sold the door and found me two good 52 doors and moved on. Maybe someone else has actually done it and will chime in later. | | | | | Joined: Nov 2006 Posts: 180 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 180 | thanks for the help....heres the problem I am faced with. My 50 has wing window doors on it, that are rotten at the bottoms. A while back, I got all the patch panels to make my doors nice again. In the meantime, a real nice non-wing window door has "landed" in my parts pile, with no rustout anywhere. So I dont know which direction to go.
| | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | Its a whole lot easier to change out the doors than to make them something they weren't. Some of the bracket inside are spot welded on and removal and replacement is going to drive you batty. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | The wingless doors are more attractive. I would use them as they came, Scott | | |
