3 members (55shaker, Jon G, BillCollins), 133 guests, and 2 robots.
Topics128,080
Posts1,055,956
Members48,430
#327389 03/18/2006 8:54 PM
I havn't been able to find anyone that sells just inner door skins. Some joker cut speaker holes in my doors before I bought the truck and now I'd like to weld in some replacement metal before I start painting.
Any ideas?
#327390 03/18/2006 9:04 PM
Brothers Truck has this one. The picture online is not the actual one. The one show in their catalog shows it as it should be.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#327391 03/18/2006 11:56 PM
2 Offline
You will probably have to find a couple of old beat up doors for the panels you are looking for. Most doors have good inner panels in the salvage yard.
#327392 03/19/2006 4:33 PM
I made patch panels to cover my speaker holes. Used an old pushrod as a form and hammered the metal around it to make the groove. Groove it, then cut to size. I can't even tell they've been patched.
#327393 03/26/2006 3:53 AM
NM51, my 46 doors were the same, with holes.
Check the pictures of what I did to cover my door skins. I used pvc,3/8 closed cell foam and tweed material.
http://community.webshots.com/user/46metal
