1 members (Gdads51),
57
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,056 Posts1,055,799 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I havn't been able to find anyone that sells just inner door skins. Some joker cut speaker holes in my doors before I bought the truck and now I'd like to weld in some replacement metal before I start painting.
Any ideas?
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Brothers Truck has this one. The picture online is not the actual one. The one show in their catalog shows it as it should be. Scott | | | | | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | You will probably have to find a couple of old beat up doors for the panels you are looking for. Most doors have good inner panels in the salvage yard. | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | I made patch panels to cover my speaker holes. Used an old pushrod as a form and hammered the metal around it to make the groove. Groove it, then cut to size. I can't even tell they've been patched. | | | | | Joined: Jul 2004 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 85 | NM51, my 46 doors were the same, with holes. Check the pictures of what I did to cover my door skins. I used pvc,3/8 closed cell foam and tweed material. http://community.webshots.com/user/46metal | | |
