| | | Forums66 Topics128,134 Posts1,056,402 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | hiyas.
My door has been getting kidna picky about closing all of the way. I started looking into it, and I found that if I lifted it up just a bit as clsoed it, it would latch easily without slamming.
So I opened the door up and go to looking at the hinges... when I lift up jsut a little bit, it seems that the top hinge wiggles some. I am curious if maybe there is something in there that is worn out, or if maybe the door pin is cracked/broken.
any ideas?
thx,
-W | | | | | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | There is a bushing and pin kit you can get that usually fixes this problem. You can get them from any of the on-line shops. Sometimes you can get them from Autozone and Checker. | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | on my camaro i loosened up the top hinge and slid it foward a tad. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I do know something about this Woog. I did the hinge pins and bushings on my 64 a while back. After I took the hinges off the truck, I couldn't get them apart for anything. I ended up hack sawing between the two parts of the hinge so I could drive the pins and bushings out. Once apart it's easy. I just reemed a drill bit through the hinge until the bushing drove in with light resistance. Then reassemble the hinge with plenty of lubrication and put it back on the truck. Spent more time getting the adjustment right than doing anything else. Consider new door stays while you're at it too, Scott | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | | | |
