3 members (Stewart2, 55shaker, 1 invisible), 145 guests, and 3 robots.
Topics128,165
Posts1,057,010
Members48,458
I have a 61' Apache. Radio was optional. Don't wanna cut any holes in the dash, and would like to install a stereo in my glove box. Has anyone done this before? I might be in for a real bear so any help is appreciated. Thanks.
- Will
"Remember Who You Are And What You Represent"
"Being responsible sometimes means [censored] people off"
- General Colin Powell
PO had one in there but it was a hack job. I ripped it all out and threw it away. Sorry no advice...but I've been thinking along the same lines.
Daily Driver 63 C-10 LWB Fleetside
doesn't yer truck have the "delete" plate to cover the radio mounting hole?? you can get good modern units that will fit in the original hole w/ no mods - only reason for puttin it in the glovebox is to keep it outta sight of the bad guys - you could put it under the seat easier, and save the glovebox space for the gloves
I had a CD player in the glovebox of my car in high school. I put it there to make life easier for me, and I was worried it would get jacked. It was a really expensive CD player and I wanted it to be safe. I got a RF (radio frequency) remote for it operated the CD player with the glovebox door closed. It was a cool setup. I had to lengthen the wiring harness that came with the stereo. It also made running my speakers a little more interesting, but no too much. I made a metal box to hold it and screwed it into the glovebox. I painted the housing black and it looked good. It was a nice setup and I didn't have to pull apart my facotry dash, I just unplugged the stereo. It is not a hard setup to build or install, I say go for it.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
my brilliant PO welded shut the radio mounting hole in the dashboard on my 53 gmc, so i couldn't add any radio without welding/cutting/torching. i put a cd in the glove compartment and it works fine. wish i'd gotten one with an RF remote so i don't have to open the door to change stations though. also, i still have the 6v setup, so i had to run a converter which i'm afraid to leave hot all the time so i lose my station settings and volume level settings whenever i shut the engine off. it works okay though. the only indication of a radio is the antenna. i thought about the hidden ones but didn't get a warm fuzzy on them working too well, so just went with the model that is spring loaded in the base like i remember in the old days seeing on cars and trucks. got it at my FLAPS.
tony
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
I've thought about this too. I also had an earlier post about iPods..that's really all I want to do, but so far seems like I need a radio head unit either way I go. Also looked at the "Secret Audio" units, but I'm a little leery of those..may be more ($$$) than I really need. And doesn't take a iPod. But, yeah, I think about the glove box. Iwas also told that another good spot is above the driver's sun visor. Good luck.
How about an overhead console? It'd be a pain running the wiring,but hey-no pain,no gain,huh?
Speed
BTW-if you do go with the glovebox,don't forget a good ground wire to the stereo case!
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
i have kinda been thinking bout this the past couple days on where to mount a CD player in my '64 chevy because only one door has a lock in the handle and i don't want to cut up my dash either but yet i don't want it in the glove box cause then it'd be a pain to put in cds or change stations so i was gona go with a under dash mount and figure out some way to have it retract up in the dash or go with bucket seats then have a locking center counsle but i'd prefer to keep the bench
Nate
Link to my photobucket for pics of my vehicles
http://s238.photobucket.com/albums/ff17/OldIronChevy/
Z
Z Offline
i would buy a custom fit radio from www.customautosound.com
I bought a custom autosound unit and it went south on me in about a month. No warrantee cause it sat on a shelf for too long before I installed it. :mad: They are very cheaply made in my opinion. They are mostly chrome plastic. The thing DOES look nice in the factory radio position. I wouldn't buy one just for that though. :rolleyes:
I have had custom autosounds in most of my old cars and trucks . Went in with no problems and didnt have any problems with working after 4 yrs in my longest installation. As far as putting a stereo in the glove box my friend build a stainless steel box patterned after the cardboard glove box. Then he cut out the holes needed for the stereo . Looked great and did the job. I also plan on putting a custom autosound stereo with remote cd in my 57.
Moderated by  truckernix
