0 members (),
164
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 38 New Guy | | New Guy Joined: Dec 2005 Posts: 38 | I have a 61' Apache. Radio was optional. Don't wanna cut any holes in the dash, and would like to install a stereo in my glove box. Has anyone done this before? I might be in for a real bear so any help is appreciated. Thanks.
- Will
"Remember Who You Are And What You Represent"
"Being responsible sometimes means [censored] people off" - General Colin Powell
| | | | | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | PO had one in there but it was a hack job. I ripped it all out and threw it away. Sorry no advice...but I've been thinking along the same lines. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | doesn't yer truck have the "delete" plate to cover the radio mounting hole?? you can get good modern units that will fit in the original hole w/ no mods - only reason for puttin it in the glovebox is to keep it outta sight of the bad guys - you could put it under the seat easier, and save the glovebox space for the gloves
Bill | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | I had a CD player in the glovebox of my car in high school. I put it there to make life easier for me, and I was worried it would get jacked. It was a really expensive CD player and I wanted it to be safe. I got a RF (radio frequency) remote for it operated the CD player with the glovebox door closed. It was a cool setup. I had to lengthen the wiring harness that came with the stereo. It also made running my speakers a little more interesting, but no too much. I made a metal box to hold it and screwed it into the glovebox. I painted the housing black and it looked good. It was a nice setup and I didn't have to pull apart my facotry dash, I just unplugged the stereo. It is not a hard setup to build or install, I say go for it.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | my brilliant PO welded shut the radio mounting hole in the dashboard on my 53 gmc, so i couldn't add any radio without welding/cutting/torching. i put a cd in the glove compartment and it works fine. wish i'd gotten one with an RF remote so i don't have to open the door to change stations though. also, i still have the 6v setup, so i had to run a converter which i'm afraid to leave hot all the time so i lose my station settings and volume level settings whenever i shut the engine off. it works okay though. the only indication of a radio is the antenna. i thought about the hidden ones but didn't get a warm fuzzy on them working too well, so just went with the model that is spring loaded in the base like i remember in the old days seeing on cars and trucks. got it at my FLAPS. tony
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
| | | | | Joined: Dec 2004 Posts: 56 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 56 | I've thought about this too. I also had an earlier post about iPods..that's really all I want to do, but so far seems like I need a radio head unit either way I go. Also looked at the "Secret Audio" units, but I'm a little leery of those..may be more ($$$) than I really need. And doesn't take a iPod. But, yeah, I think about the glove box. Iwas also told that another good spot is above the driver's sun visor. Good luck. | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | How about an overhead console? It'd be a pain running the wiring,but hey-no pain,no gain,huh? Speed BTW-if you do go with the glovebox,don't forget a good ground wire to the stereo case! | | | | | Joined: Sep 2005 Posts: 254 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 254 | i have kinda been thinking bout this the past couple days on where to mount a CD player in my '64 chevy because only one door has a lock in the handle and i don't want to cut up my dash either but yet i don't want it in the glove box cause then it'd be a pain to put in cds or change stations so i was gona go with a under dash mount and figure out some way to have it retract up in the dash or go with bucket seats then have a locking center counsle but i'd prefer to keep the bench Nate | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | i would buy a custom fit radio from www.customautosound.com | | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | I bought a custom autosound unit and it went south on me in about a month. No warrantee cause it sat on a shelf for too long before I installed it. :mad: They are very cheaply made in my opinion. They are mostly chrome plastic. The thing DOES look nice in the factory radio position. I wouldn't buy one just for that though. :rolleyes: | | | | | Joined: Jun 2005 Posts: 209 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 209 | I have had custom autosounds in most of my old cars and trucks . Went in with no problems and didnt have any problems with working after 4 yrs in my longest installation. As far as putting a stereo in the glove box my friend build a stainless steel box patterned after the cardboard glove box. Then he cut out the holes needed for the stereo . Looked great and did the job. I also plan on putting a custom autosound stereo with remote cd in my 57. | | |
