| | | Forums66 Topics128,126 Posts1,056,351 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 56 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 56 | Anyone have any advice or experience with heat shields for the bottom side of their bed wood? I've seen them, but don't know if I need them or not. I have about 3-1/2" between the top of the tailpipe where it curves up and over the axle, and the underside of my nice new shiny bed wood (spar varnish finish both sides). I had a '62 GMC long-bed that had some bed wood damage from heat, so I guess that should tell me something!! :p Many thanks. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | None of the stock trucks i've seen have had any heat sheild, nor have I seen any under bed wood damage as a result of heat.. but when I was putting the wood in my '46 1/2 ton the thought crossed my mind.
I wonder if a 6 exhaust gets all that hot in the first place? I know it's been 90 outside and i've run the crap out of both my trucks and while the exhaust pipe would definately be hot to the touch, I didn't feel any significant heat radiating from the pipe.
If you've got a fancy finish on your bed wood, tho.. i'd guess radiated heat could break the finish down over time, and eventually let moisture in.
All absolute speculation, tho.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I've been wrong once or twice in my life  but I don't think you'll have a problem unless you do a lot of sitting still with the engine running. Even low speed driving should circulate enough air to keep the wood from being damaged.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I do not know if the heat shield is necessary on 47-55 trucks (on the lower side of the bed/floor on a pickup, panel, canopy, suburban, or any model with wood above the "hump" in the tailpipe); however, the heat shield was most likely standard equipment on these trucks.
I say "most likely" because I never saw a factory-fresh truck; however, the two 1/2 ton A-D trucks that I bought in the late 60s-early-70s both had a heat shield.
I think that Mar-K (and maybe others) is now selling a stainless steel version of the heat shield.
There has been no heat shield under the varnished bed boards on my dual-exhaust'54 pickup for about 7 years - I see no problems. However, I am taking no chances with my suburban - I replaced the old (? original) heat-shield with a POR-painted new one.
Tim | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | my 37 had a heat shield over the muffler, whether original or not I don't know. I run a 350 with staight pipes and it has not done any damage to the underside wood which I also have Spar-urethane on. I "heat it up" ever now and then but don't see a problem. Just my .02 cent. | | | | | Joined: Aug 2004 Posts: 47 Member | | Member Joined: Aug 2004 Posts: 47 | My '57 had one... At least the assembly manual calls for it. | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | My 59 fleetside (original wood) had one and we recommend it as cheap insurance. The stainless ones actually look pretty nice under the wood. Kind of a purposeful blend of form and function. Mar-K makes two sizes in both steel and stainless, http://www.mar-k.com/various_restoration_items.pdf as the trucks used a larger shield after 1973. You don't want to find out you needed one when the wood starts smoking. Mar-Ktech | | | | | Joined: Dec 2004 Posts: 56 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 56 | Many thanks all. Liek you all say, it is relatively cheap insurance. I want the finish and the wood to last. Thats one job I don't want to have to do again. | | |
