2 members (Otto Skorzeny, 1955 1 Series), 116 guests, and 0 robots.
Topics128,115
Posts1,056,294
Members48,439
#325023 01/11/2006 3:49 PM
Anyone have any advice or experience with heat shields for the bottom side of their bed wood? I've seen them, but don't know if I need them or not. I have about 3-1/2" between the top of the tailpipe where it curves up and over the axle, and the underside of my nice new shiny bed wood (spar varnish finish both sides). I had a '62 GMC long-bed that had some bed wood damage from heat, so I guess that should tell me something!! :p Many thanks.
#325024 01/11/2006 4:00 PM
None of the stock trucks i've seen have had any heat sheild, nor have I seen any under bed wood damage as a result of heat.. but when I was putting the wood in my '46 1/2 ton the thought crossed my mind.
I wonder if a 6 exhaust gets all that hot in the first place? I know it's been 90 outside and i've run the crap out of both my trucks and while the exhaust pipe would definately be hot to the touch, I didn't feel any significant heat radiating from the pipe.
If you've got a fancy finish on your bed wood, tho.. i'd guess radiated heat could break the finish down over time, and eventually let moisture in.
All absolute speculation, tho.
#325025 01/11/2006 4:18 PM
Ex Hall Monitor
Ex Hall Monitor
I've been wrong once or twice in my life grin but I don't think you'll have a problem unless you do a lot of sitting still with the engine running. Even low speed driving should circulate enough air to keep the wood from being damaged.
#325026 01/11/2006 4:20 PM
I do not know if the heat shield is necessary on 47-55 trucks (on the lower side of the bed/floor on a pickup, panel, canopy, suburban, or any model with wood above the "hump" in the tailpipe); however, the heat shield was most likely standard equipment on these trucks.
I say "most likely" because I never saw a factory-fresh truck; however, the two 1/2 ton A-D trucks that I bought in the late 60s-early-70s both had a heat shield.
I think that Mar-K (and maybe others) is now selling a stainless steel version of the heat shield.
There has been no heat shield under the varnished bed boards on my dual-exhaust'54 pickup for about 7 years - I see no problems. However, I am taking no chances with my suburban - I replaced the old (? original) heat-shield with a POR-painted new one.
Tim
#325027 01/11/2006 9:36 PM
my 37 had a heat shield over the muffler, whether original or not I don't know. I run a 350 with staight pipes and it has not done any damage to the underside wood which I also have Spar-urethane on. I "heat it up" ever now and then but don't see a problem. Just my .02 cent.
#325028 01/11/2006 11:01 PM
My '57 had one... At least the assembly manual calls for it.
#325029 01/12/2006 12:08 AM
My 59 fleetside (original wood) had one and we recommend it as cheap insurance. The stainless ones actually look pretty nice under the wood. Kind of a purposeful blend of form and function. Mar-K makes two sizes in both steel and stainless, http://www.mar-k.com/various_restoration_items.pdf as the trucks used a larger shield after 1973. You don't want to find out you needed one when the wood starts smoking.
Mar-Ktech
#325030 01/12/2006 4:25 AM
Many thanks all. Liek you all say, it is relatively cheap insurance. I want the finish and the wood to last. Thats one job I don't want to have to do again.
