6 members (Hotrod Lincoln, 48ed56pam, Ponchogl, lumbersawyer, MickeyP, Bill Hanlon), 136 guests, and 2 robots.
Topics128,081
Posts1,056,073
Members48,434
#29915 05/07/2005 8:04 PM
I've heard it said that if you want to go with a multi-carb setup on your engine, then the number of carbs should be based on the number of cylinders to get the best performance. For example, a 6 cylinder should have either 3 or 6 carbs.
Has anyone else heard this? If this is true, then why?? I know that there are hundreds if not thousands of dual-carb setups on Chevy 6's out there. Would the addition of a third carb make that much more difference on a 6?
Inquiring minds want to know.
#29916 05/07/2005 10:41 PM
I've never heard that, at least until now. My suspicion is that it is an old wives tale from the days when understanding airflow through the manifold was not a science but more smoke and mirrors. In that scenario one carb for each set of intake ports probably made sense to some. Todays intakes work a lot better and one 390 CFM 4bbl works really well. 3 & 6 carbs have linkage and firewall clearance problems on a lot of cars & trucks and that is a real good reason to avoid them but the WOW factor is lost too.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#29917 05/08/2005 4:02 AM
H Online: Content
One man/one vote, and one engine/one carb! Some things are just too good to tinker with! If you want the geewhiz factor, get a 3-carb manifold, and put blind gaskets under the outboard carbs. Then you can have the reliability of a single and the looks of a triple setup. The time, effort amd MONEY you'll spend making a multi-carb setup work, some of the time, can be spent doing more enjoyable things!
#29918 05/08/2005 9:06 PM
Apprentice
Apprentice
On a practical level, I have to agree with Hotrod Lincoln on this one. My truck has a 283 (2-bbl Rochester, ram horn manifolds, etc), and everything you read about these engines basically boils down to "for street use, put on a 500-600cfm 4-bbl carb, headers if you want, and away you go." So on that basis, I should go find the manifold/carbs/cylinder heads from the 283 "power pack" and call it a day.
On the romantic / inspiration side, though: Every time I open the hood, I see the Rochester 2G sitting there on the motor but, in my head, I see three Stromberg 97s. I have spent too much time looking at tri-power setups on hoodless hot rods to really want anything else, in the long run--even for a driver/hauler truck that will never see a race track. And I think this way even after hearing horror stories from a friend of mine with a Corvair about syncing his carbs. I figure it's only a matter of time!
