0 members (),
106
0
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29915 05/07/2005 8:04 PM | Joined: Oct 2003 Posts: 94 'Bolter | | 'Bolter Joined: Oct 2003 Posts: 94 | I've heard it said that if you want to go with a multi-carb setup on your engine, then the number of carbs should be based on the number of cylinders to get the best performance. For example, a 6 cylinder should have either 3 or 6 carbs.
Has anyone else heard this? If this is true, then why?? I know that there are hundreds if not thousands of dual-carb setups on Chevy 6's out there. Would the addition of a third carb make that much more difference on a 6?
Inquiring minds want to know. Thanks | | |
#29916 05/07/2005 10:41 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I've never heard that, at least until now. My suspicion is that it is an old wives tale from the days when understanding airflow through the manifold was not a science but more smoke and mirrors. In that scenario one carb for each set of intake ports probably made sense to some. Todays intakes work a lot better and one 390 CFM 4bbl works really well. 3 & 6 carbs have linkage and firewall clearance problems on a lot of cars & trucks and that is a real good reason to avoid them but the WOW factor is lost too. | | |
#29917 05/08/2005 4:02 AM | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | One man/one vote, and one engine/one carb! Some things are just too good to tinker with! If you want the geewhiz factor, get a 3-carb manifold, and put blind gaskets under the outboard carbs. Then you can have the reliability of a single and the looks of a triple setup. The time, effort amd MONEY you'll spend making a multi-carb setup work, some of the time, can be spent doing more enjoyable things! Jerry
#29918 05/08/2005 9:06 PM | Joined: Feb 2005 Posts: 42 Apprentice | | Apprentice Joined: Feb 2005 Posts: 42 | On a practical level, I have to agree with Hotrod Lincoln on this one. My truck has a 283 (2-bbl Rochester, ram horn manifolds, etc), and everything you read about these engines basically boils down to "for street use, put on a 500-600cfm 4-bbl carb, headers if you want, and away you go." So on that basis, I should go find the manifold/carbs/cylinder heads from the 283 "power pack" and call it a day.
On the romantic / inspiration side, though: Every time I open the hood, I see the Rochester 2G sitting there on the motor but, in my head, I see three Stromberg 97s. I have spent too much time looking at tri-power setups on hoodless hot rods to really want anything else, in the long run--even for a driver/hauler truck that will never see a race track. And I think this way even after hearing horror stories from a friend of mine with a Corvair about syncing his carbs. I figure it's only a matter of time! | | |
