| | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29706 10/25/2004 2:46 AM | Joined: Oct 2004 Posts: 1 Junior Member | | Junior Member Joined: Oct 2004 Posts: 1 | I have a 235 chevy engine that runs fine until I hit 55_60 mph it shuts down like it is out of fuel, back it off to 40-50 mph it runs fine, accellerate to 55-60 it shuts down again, any ideas?suggestions?theories? e-mail me: [email protected]thanks, bill
bill j. harris
#29707 10/25/2004 3:15 AM | Joined: Jun 2004 Posts: 19 Junior Member | | Junior Member Joined: Jun 2004 Posts: 19 | I had a 68 Chevy do the same thing, didn't take long to figure out there was a lot of trash in the fuel tank, and would stop up the fuel filter, could go 60 easily for a while then as the filter stopped up, top speed would fall off.
Could be the pump just not keeping up with the demand at 50 - 60, but just enough to allow a slower speed. Check the sock in the tank too.
You are probably right, sounds like it is starving for fuel. | | |
#29708 10/25/2004 3:20 AM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I think you got it right. It gets out of fuel. What carb, how adjusted? How's the fuel filter? How's the fuel pump? I'd say change the filter and pump and go from there. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#29709 10/25/2004 4:16 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Does it die completely when this happens? If it does, leave it shut off, pull over (only if it's safe to do this) and see if the carb has any fuel. If the accelerator pump pumps little or nothing, I would say you have a supply problem. Usually a pump and/or filter problem. Good luck, Scott | | |
#29710 10/25/2004 4:17 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | nother thing to look at is wear on the fuel pump drive lever - I had one that was worn just enuff to act like yours, but at lower speeds going uphill - not pumping a full stroke so couldn't keep up w/ demand - worked fine on the level
Bill | | |
#29711 10/26/2004 3:02 AM | Joined: Jul 2004 Posts: 18 Apprentice | | Apprentice Joined: Jul 2004 Posts: 18 | Used to happen to me a lot. I carried a case of fuel filters with me until I finally got the tank boiled - for about ten bucks, as I recall. When checking fuel supply, don't forgt to occasionally check the ceramic filter inside the carb itself - right where the fuel line screws in.
'63 half-ton another '63 half-ton '62 school bus
