Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (mo2cyl, Rusty Heaps), 59 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#29706 10/25/2004 2:46 AM
Junior Member
Junior Member
I have a 235 chevy engine that runs fine until I hit 55_60 mph it shuts down like it is out of fuel, back it off to 40-50 mph it runs fine, accellerate to 55-60 it shuts down again, any ideas?suggestions?theories?
e-mail me:[email protected]
thanks,
bill
bill j. harris
#29707 10/25/2004 3:15 AM
Junior Member
Junior Member
I had a 68 Chevy do the same thing, didn't take long to figure out there was a lot of trash in the fuel tank, and would stop up the fuel filter, could go 60 easily for a while then as the filter stopped up, top speed would fall off.
Could be the pump just not keeping up with the demand at 50 - 60, but just enough to allow a slower speed.
Check the sock in the tank too.
You are probably right, sounds like it is starving for fuel.
#29708 10/25/2004 3:20 AM
I think you got it right. It gets out of fuel. What carb, how adjusted? How's the fuel filter? How's the fuel pump? I'd say change the filter and pump and go from there.
#29709 10/25/2004 4:16 AM
Does it die completely when this happens? If it does, leave it shut off, pull over (only if it's safe to do this) and see if the carb has any fuel. If the accelerator pump pumps little or nothing, I would say you have a supply problem. Usually a pump and/or filter problem.
Good luck,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#29710 10/25/2004 4:17 AM
nother thing to look at is wear on the fuel pump drive lever - I had one that was worn just enuff to act like yours, but at lower speeds going uphill - not pumping a full stroke so couldn't keep up w/ demand - worked fine on the level
#29711 10/26/2004 3:02 AM
f63 Offline
Apprentice
Apprentice
Used to happen to me a lot. I carried a case of fuel filters with me until I finally got the tank boiled - for about ten bucks, as I recall.
When checking fuel supply, don't forgt to occasionally check the ceramic filter inside the carb itself - right where the fuel line screws in.
'63 half-ton
another '63 half-ton
'62 school bus
