Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (dt235sd, Sjm), 99 guests, and 2 robots.
Topics128,283
Posts1,058,505
Members48,490
Got an 848 head that I want to get completely redone. New valves, seats, guides, springs, etc. Head cleaned and fluxed and all the normal stuff. Would appreciate an approximate cost of doing this from your experience if I furnish all of the parts to the machine shop. In addition, if anyone in the Maryland, DC or Virginia area knows of a good, reputable shop, I'd appreciate that too. Don't want to make a costly mistake or get taken.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
49-
Had a pair of heads reworked for my 305 SBC-V8. Cost around $275 at one of the best regional shops with higher tech machining tools.
Sorry, you're in the "other" Washington, so I can't recommend anything local! :rolleyes:
Most (a lot) machine shops also sell the parts and want to use thier own stuff. So if you take the parts to them they will likely charge you more than if they supply them. What is so special about your own parts?
This is like taking your own oil to the garage guy and asking him to change it. wink
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Want to buy most of the parts so I don't have to hear cra* about them not being able to get stuff for the old 6 banger. Patricks has most if not all I need. wink
V
V Offline
Like money pit said, you might a lot of places won't let you bring all the parts...
I had my 848 done for $400, parts and labor.
1959 3200 Apache Fleetside
In the Legacy Gallery
Let the machine shop supply the parts. I had a 228 GMC engine completely rebuilt and the machine shop supplied everything. They never mentioned having any trouble finding parts.
If you supply the parts and anything goes wrong with the head they may be quick to blame YOUR parts.. Let them do the whole job. If there are any problems, they are fully accountable..
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
V
V Offline
oops, should have previewed my post....
...pulled a george w!
