2 members (dt235sd, Sjm),
99
Mod | | | Forums66 Topics128,283 Posts1,058,505 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Got an 848 head that I want to get completely redone. New valves, seats, guides, springs, etc. Head cleaned and fluxed and all the normal stuff. Would appreciate an approximate cost of doing this from your experience if I furnish all of the parts to the machine shop. In addition, if anyone in the Maryland, DC or Virginia area knows of a good, reputable shop, I'd appreciate that too. Don't want to make a costly mistake or get taken. | | | | | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | 49-
Had a pair of heads reworked for my 305 SBC-V8. Cost around $275 at one of the best regional shops with higher tech machining tools.
Sorry, you're in the "other" Washington, so I can't recommend anything local! :rolleyes: | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Most (a lot) machine shops also sell the parts and want to use thier own stuff. So if you take the parts to them they will likely charge you more than if they supply them. What is so special about your own parts? This is like taking your own oil to the garage guy and asking him to change it.  | | |
#2758 02/10/2004 10:47 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Want to buy most of the parts so I don't have to hear cra* about them not being able to get stuff for the old 6 banger. Patricks has most if not all I need.  | | |
#2759 02/10/2004 10:58 PM | Joined: Oct 2002 Posts: 96 'Bolter | | 'Bolter Joined: Oct 2002 Posts: 96 | Like money pit said, you might a lot of places won't let you bring all the parts... I had my 848 done for $400, parts and labor. | | |
#2760 02/10/2004 11:01 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Let the machine shop supply the parts. I had a 228 GMC engine completely rebuilt and the machine shop supplied everything. They never mentioned having any trouble finding parts.
If you supply the parts and anything goes wrong with the head they may be quick to blame YOUR parts.. Let them do the whole job. If there are any problems, they are fully accountable..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#2761 02/10/2004 11:02 PM | Joined: Oct 2002 Posts: 96 'Bolter | | 'Bolter Joined: Oct 2002 Posts: 96 | oops, should have previewed my post.... ...pulled a george w! | | |
