0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#25599 03/19/2005 6:54 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Seems that today most folks have a distaste for PowerGlide trannies for a few good reasons. I have a buddy with one hooked up to a 350 in his AD and it works very well. I have a chance to get one at a good price to stick behind my 1956 era 235. The motor is stock and the truck is never driven hard or above 50 mph. Wondering if I really need a TH350 or 700 in this case. | | |
#25600 03/19/2005 7:50 PM | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I had a 56 BelAir a few years ago.It had a 235 and PG.Wasnt much good for drag racing,but moved right along. | | |
#25601 03/19/2005 8:28 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Alright, got my curiousity up...can I hook up an old powerglide to my 54 235 without too much work? currently has a 4spd and gave up drag racing for cruising since i'm six years older than the truck | | |
#25602 03/19/2005 10:02 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | There are two different Powerglides out there. The early cast iron ones and the later alloy case ones.
The cast iron version was used behind a 235 so putting one behind yours would be easy. However, they were not great transmissions and aren't easy to find parts for.
The later one can be put behind a 235 using the same adapter used to put a TH350 for 700R4 behind a 235.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#25603 03/19/2005 10:28 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Thanks, OldSub...don't have facilities for a lot of machine work, so was looking for something as easy a swap as possible..do have access to a bone yard, so just need some info on what to look for...I've got some books, and ordered more, but don't have anything on a trans adapter..that old 4spd is working just fine, but would kinda just like to use my armstrong power steering with the cowl vent open..might be willing to trade this trans, if i can get some help on a auto install | | |
#25604 03/19/2005 10:49 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | shooper, go to www.stoveboltengineco.com for the adapter. i also think there is tech page on it. hope this helps. also buffaloenterprises offers one i dont't know much about them.. there are some threads in the search area on this site. put in trans adapter and the pages will come up. lots of comments there good and bad.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
#25605 03/19/2005 11:02 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | shooper, btw there is abook put out by tex smith written by rich johnson called how to build chevy hot rods, book one. mine is so old there may be a book 2 or 3. a whole chapter is devoted to transmissions auto and stick. sizes uses and gear ratios. they also say the pg was used for up to 400hp and also the 4cyl vegas.because being used for drag racing a lot of parts are availble. langdons has a how to section they explains all about changing to auto.
#25606 03/19/2005 11:41 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Thanks, We b Old..seen a lot of pg's in drag racing through the years...also, went to Langdons site, and they want $350.00 for an adapter..I don't think so...just want something different than this 4spd without messing with my rearend...I like the 3.90..appreciate your help bro.. | | |
#25607 03/20/2005 1:22 AM | Joined: Aug 2004 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 52 | Olblu, I don't have any experience with powerglides, but what I hear by word of mouth says the things are just about indestructable. A lot of circle track and drag racers use them, so they have to be good for lots of torque and horsepower. The final drive ratio is 1:1, so the cruising RPMs won't be any different than a normal (non-overdrive) tranny. The biggest drawback to the PG is that since it only has two speeds, it doesn't accelerate nearly as well as other trannies.
1946 GMC 1/2 ton 1967 Chevy 1/2 ton
This old truck sure looks neat, but where are the heated seat controls?!?
#25608 03/20/2005 3:39 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | If you go to all of the expense of adapting a powerglide to a 235, put a th350 in instead. They're a dime a dozen, easy to find, have 3 gears and are every bit as tough as a 'glide. I built one and had it behind 400 h.p. in my old Impala and it was the only thing that I never broke. Just my 2 cents worth, Scott | | |
#25609 03/20/2005 3:05 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | shooper , then try www.patricksantiquecars.com, may not be much cheaper but you can keep the torgue tube. wish he had this when i started 20 yrs ago. ron
#25610 03/20/2005 3:13 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | WE b OLD...don't have a torque tube...open drive shaft w/center bearing...waiting for my Patricks catalog to arrive...thanks for info | | |
#25611 03/20/2005 3:29 PM | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | If you wanna keep the 3.90s then a 700R4 is for you.A PG or 350 is a 1 to 1 coming out of the tranny,whereas the 700R4 is approx .78 to 1 | | |
#25612 03/20/2005 3:34 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Thanks dale937..can you fill me in on that 700R4..what was it originally in so I can go junkyard shopping? | | |
#25613 03/20/2005 9:21 PM | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I traded for mine,it is supposed to be out of a late 80s Chevy PU.The guy I got it from rebuilt it.It is in my 55 2nd with a 350 engine and stock rear,3.90 gears and it runs right along with the fast traffic,plus with the low gear in the 700R4 it jumps right out there from a dead stop. | | |
#25614 03/21/2005 12:12 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | How does the size of the PowerGlide compare to a TH350? I mentioned putting in a PG this morning and the general consensus was that the TH350 was more readily available and probably the same size. | | |
#25615 03/21/2005 12:22 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Should be a direct bolt in if the 'glide is already installed, with the exception of the driveshaft yoke. It has a different spline count. If you buy one from a yard, just be sure to get the driveshaft that came with it (for the yoke). Scott | | |
#25616 03/25/2005 5:48 PM | Joined: Mar 2005 Posts: 10 Junior Member | | Junior Member Joined: Mar 2005 Posts: 10 | My 2 cents, I have heard the very early cast iron glides with torque tubes were air cooled. The later alloy cases required fluid cooling by the radiator. | | |
