6 members (rfs56trk, J Lucas, Steelonsteel, Wally / Montana, greenie-reddy, sron48), 125 guests, and 5 robots.
Topics128,269
Posts1,058,399
Members48,485
Apprentice
Apprentice
Ok guys,I have all my engine #s. At least I think I got em right. 1st it has 2 side engine mounts. The valve cover has 6 small screws around the "rim" of it to hold it on. The 1st thing I see on the starter side of the block.Starting from the rear is the letters CON [I think] right below it is a clock dial symbal w/the hand pointing sraight up. to the right of that the #s E208[I think] then 3821963 Below that the letters GM & the # 70 below that. Now Ive looked on the lists the tech dept. has & cant find these #s on any of them. Think I could get one of you nice fellows to help a guy out before I start a serious drinking problem?? Thanks for any input. Jeff
check for the engine # next to the distributor
Apprentice
Apprentice
Quote
OK, I did. The # right next to the distributor is 28F & below that the # 2710 Thanks for your reply,does that sound like a # that can be used to find out what the heck this is? Thanks again. Jeff
I thought that the 194-292 series engines had seven valve cover screws, late 235 had four and early 235, 216, 206, 182, 194 had two.
Apprentice
Apprentice
Quote
I dunno,Is this a question or...?
Apprentice
Apprentice
Well,guess I got everybody stumped. Or I havent given the right info. out to help.Still would like to know what engine I have so I can see if I can swap trannys to an automatic,maybe elect.ign.& get my gauges done correctly. ANYBODY??? Any input would be helpful. Thanks again. Jeff
52 panel, take your #'s to an old garage who would still have some books of the listings laying around. There is a web site for V8's which is mortec.com but I don't think it list 6 cylinders. I am not sure about Inliners web site as I have not been there.....just hang tight. The answer will come.
somewhere I read to check chuckthetruck web site.... I think???
go to www.inliners.org scroll down to casting numbers.
"It ain't a truck if you can't hose out the cab."
oh yea, the cast in numbers on the right side of the head could help also.
left right im (((((up left side of head, right side of block. cast in numbers are what you want to look for. by the distributor are stamped in numbers, they are harder to find info, but i seen something some place. My 54 and 39 both have 2 nuts holding the valve cover. my guess is later model.
X
X Offline
Double check the block casting number. The number given may not be a valid number. Sometimes the digits in these casting numbers are hard to distinguish. The closest number I've found is 3921968, which would be for a 64-76 230 or 250, according to Inliners. The casting date of E208 would then translate to May 20, 1968.
The given numbers by the distributor do not follow the usual engine series number format. We're these the numbers stamped into the pad just aft of the distributor? This could have been a replacement engine.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
