0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 22 Apprentice | | Apprentice Joined: Apr 2006 Posts: 22 | Ok guys,I have all my engine #s. At least I think I got em right. 1st it has 2 side engine mounts. The valve cover has 6 small screws around the "rim" of it to hold it on. The 1st thing I see on the starter side of the block.Starting from the rear is the letters CON [I think] right below it is a clock dial symbal w/the hand pointing sraight up. to the right of that the #s E208[I think] then 3821963 Below that the letters GM & the # 70 below that. Now Ive looked on the lists the tech dept. has & cant find these #s on any of them. Think I could get one of you nice fellows to help a guy out before I start a serious drinking problem?? Thanks for any input. Jeff | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | check for the engine # next to the distributor | | | | | Joined: Apr 2006 Posts: 22 Apprentice | | Apprentice Joined: Apr 2006 Posts: 22 | Originally posted by Achipmunk: check for the engine # next to the distributor OK, I did. The # right next to the distributor is 28F & below that the # 2710 Thanks for your reply,does that sound like a # that can be used to find out what the heck this is? Thanks again. Jeff | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | I thought that the 194-292 series engines had seven valve cover screws, late 235 had four and early 235, 216, 206, 182, 194 had two. | | | | | Joined: Apr 2006 Posts: 22 Apprentice | | Apprentice Joined: Apr 2006 Posts: 22 | Originally posted by Baldy: I thought that the 194-292 series engines had seven valve cover screws, late 235 had four and early 235, 216, 206, 182, 194 had two. I dunno,Is this a question or...? | | | | | Joined: Apr 2006 Posts: 22 Apprentice | | Apprentice Joined: Apr 2006 Posts: 22 | Well,guess I got everybody stumped. Or I havent given the right info. out to help.Still would like to know what engine I have so I can see if I can swap trannys to an automatic,maybe elect.ign.& get my gauges done correctly. ANYBODY??? Any input would be helpful. Thanks again. Jeff | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | 52 panel, take your #'s to an old garage who would still have some books of the listings laying around. There is a web site for V8's which is mortec.com but I don't think it list 6 cylinders. I am not sure about Inliners web site as I have not been there.....just hang tight. The answer will come. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | somewhere I read to check chuckthetruck web site.... I think??? | | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | go to www.inliners.org scroll down to casting numbers.
"It ain't a truck if you can't hose out the cab."
| | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | oh yea, the cast in numbers on the right side of the head could help also.
| | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | left right im (((((up left side of head, right side of block. cast in numbers are what you want to look for. by the distributor are stamped in numbers, they are harder to find info, but i seen something some place. My 54 and 39 both have 2 nuts holding the valve cover. my guess is later model.
| | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | Double check the block casting number. The number given may not be a valid number. Sometimes the digits in these casting numbers are hard to distinguish. The closest number I've found is 3921968, which would be for a 64-76 230 or 250, according to Inliners. The casting date of E208 would then translate to May 20, 1968.
The given numbers by the distributor do not follow the usual engine series number format. We're these the numbers stamped into the pad just aft of the distributor? This could have been a replacement engine.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
| | | | | Joined: Dec 2005 Posts: 200 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 200 | | | |
