Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Stovebolt48, cmayna), 180 guests, and 5 robots.
Topics128,283
Posts1,058,504
Members48,490
Let me ask a stupid question. I now have the 52Panel in my shop. The fellow who had it before me did redo the straight axle. King pins,arch springs,new drums etc and I was wondering if there is a power steering I can put on the original. I will most likely put the 350 in it that I have in the shop and I want to do a lot of planning before jumping right in. It is currently all original but I like to travel and go fast at times!! I would like to also know what rear end would be a good match. I know some of you out there have done this before. Any Idea's? thanks
OOPs...the post I just did above shows my email address from when I was working out of town and is no longer valid. This email will show my HOME email. Thanks/sorry.
As you will probably see from previous threads, once you go to a V8, you will need to modify the steering column becuase it will be in the way. This is the perfect time to convert to PS. The kits that I have seen use a new steering box, commonly from an 80's Toyota truck, a new Pitman arm and a revised steering column with a U-joint included.
1951 1 Ton Completed
Moderator
Moderator
Send a PM to 48BigTrucks if he doesn't find this on his own. He's done it to at least one of his and used common Chevy parts.
Don't lose your head to save a minute,
You need your head, your brains are in it.
Burma-Shave (1947)
Classic Performance and other venders have a power steering conversion for straight axle trucks.
I order a power steering kit from chevy duty for my 59 chev. It works great, easy to put on. I needed to weld a bracket on to the frame were the power steering box attached to. The bracket was included in the kit. The steering box that I used was from a mid 70's chevy truck and I used a pitman arm off a 71 chevelle because the pitman arm from the mid 70s truck was to long for my application. the truck steers very nice never had any trouble.
38 original
48 panel
59 stepside
46 in the back forty
Thanks fellows. I am a little ways off from doing this but I like to plan ahead. I will most likely start tearing it all apart next week but I print out your responses and put them in a folder for future use. This way I know what to look for and hopefully run accross it at a good price as I am in no hurry and can "shop around". thanks again.
