| | | Forums66 Topics128,082 Posts1,055,961 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Looking through all the usual catalogs for power brake booster conversions. Just about everybody has one. Pretty much decided on the underfloor frame mount type. RBs has one for $315 by Serious Hardware and in the photo looks pretty good. Blurb sez bolts right up but for automatic transmissions only. Won't work with a manual? Using th350 so doesn't matter anyway. Just wondering. I will probably go with this unit and am looking for advice from anyone who has done this type of conversion. Body is off the frame so should be pretty easy. Right? Every time I ask a question like this I get lots of good answers and haven't been disappointed yet. Thanks Bolters. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | weeds,get in touch with cletis, he just installing a disk mod an has installed the boster. if you look in the new admissions in the gallery you'll find his web page interesing. tony'n (wet} weatherford  | | | | | Joined: Sep 2000 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 60 | I'VE DONE A LOT IN THE SHOP. NO PROBLEMS HERE. BODY OFF FRAME IS ALOT BETTER TO MOUNT IT & RUN YOUR BRAKE LINES, WILL NEED TO PUT A SMALL TRAP DOOR IN FLOORBOARD TO CHECK & SERVICE IT. UNLESS YOU GO WITH A REMOTE FILL ON THE FIREWALL.
FRAMEUP TRUCKS - 47/55.1ST STILL PLAYING WITH TRUCKS | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | 2 many,Tonyn and T-man--Thanks for the advice, been laid up with an infection in my leg, almost got it whipped and am anxious to get back to work on the sub. Tony I will try to get ahold of Cletis and see what he says. Thanks again for all the advice and encouragement. What a site this Stovebolt. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Weeds, I tried to email a reply to your PM but it bounced. Click the link to my "Trucks" website then click on "54GMC" then "Front suspension" to see the problems I ran into with the kit from CPP and how I solved them. As far as clearance with the tranny, I didn't have any problems. I'm using a TH200-4R behind a 248. | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Cletis Thanks for the link to your Trucks site. I reviewed all your progress and it helped me a lot. Weeds | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Weeds: I just installed CPP booster and front brakes after researching Cletis tips and down loading the pictures from CPP Tech Files It was real easy.
I did order the remote fill because I am closing the floor hatch off. With the new booster I did have to drill 3 holes but that is just helping support it. Ben
popcorn The Truth is Out There (Glad you starting to heal Buddy any questions e-mail me) | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Weeds, I didn't catch what model truck your working on but I put the master/cyl booster under the floorboard on my 37 and glad I did. It keeps the firewall nice and clean and roomy. I did have to get creative and attach my brake switch to the bottom of the floorboard but no problem. I have it sitting against the homemade brake pedal and it works find. Good luck on yours. | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Chip I ordered mine from RBs. Supposedly a bolt up according to the blurb. It hasn't come yet. My truck is a 49 Chevy suburban. The body is off so the installation should be pretty easy. The pic in their catalog shows a brake pedal arm on the assembly. Hope it comes thru the original hole in the floor. Thanks for the encouragement and the info. Weeds | | |
