0 members (),
182
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,108 Posts1,056,228 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 141 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 141 | Hello, I joined today. I'm from Fairfax, California. The first car that I ever bought was a 54 Chevy wagon. I had it for about a dozen years and traded it off about a dozen years ago. Last week I bought a 48 GMC 1 Ton Flat Bed. You can see it at http://home.comcast.net/~chriseye/gmc.html The first things that I want to do to it are repaint the cab, and rebuild the bed. I am still trying to determine what kind of wood that I should use for the bed and the wood joists below it. I think that I am going to repaint the cab with rustoleum hunter green. What do you all think? Thanks, Chris
| | | | | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | Hi Chris, Welcome to the bolt. I like that GMC.
Cliff59 | | | | | Joined: Feb 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 190 | Welcome, Nice truck good luck with it. | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | Hi Cris,welcome to the "bolt" I can suggest fir for the joists and bed.It is much harder than pine | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Chris,
Welcome to the Stovebolt. It's interesting that the inside cab shot shows a reverse lockout lever on the shifter. In regards to Chevrolet's, I thought the last year for that was '47.
Stuart | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | wellcome to the Bolt. Your in good hands now. Sure like the truck to. | | | | | Joined: Sep 2007 Posts: 141 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 141 | Thanks everyone! After doing some research, Apitong seems like the best wood for the truck bed. It will cost almost $400 for 1x7x1 1/16" shiplap. As for the joists, I'm considering redwood, or pressure treated doug fir. Chris | | | | | Joined: Nov 2004 Posts: 2,409 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,409 |
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 | Welcome Chris, Nice truck!! Originally posted by atomarc: Chris,
Stuart I thought that also..........
1948 AD Pickup
| | | | | Joined: Sep 2007 Posts: 141 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 141 | What kind of finish did the factory put on the wood? If mine is original, it looks like it was painted green to match the truck. Did they ever use clear finishes? Thanks, Chris | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no Chris, the wood was satin black earlier, then went to body color in late 50's or so, but if you're speaking of the flatdeck on that 1 ton, it's not a factory deck, prolly the truck was bought as "cab and chassis" and the deck added by the original owner - the factory flatdecks [called "stake body" or "platform body"] had nicely rounded metal edging with 'integral' stake pockets
Bill | | | | | Joined: Sep 2007 Posts: 141 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 141 | Thanks Bill, If I read my vin right. My truck came from Oakland, Ca, about 15 miles south of the Tamalpais Cemetery (previous owner). The bed does have integral stake pockets on the sides , but not on the rear. The corners of the bed are square, not rounded, so maybe the bed was made locally also, but not by GMC. So...I could paint the wood black, or green, or clear? Thanks, Chris | | | | | Joined: Jul 2006 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 187 | Welcome Mt.Tam Trucker, Rustoleum Hunter Green is cool but Bright. see here
'36 Tall cab Chevy 1.5 ton, '36 Low cab Chevy 1.5 ton, '53 GMC 2 ton, '51 GMC 640 5 ton, '47 Dodge 2 ton, '42 GMC CCKW 353 6X6.
| | | | | Joined: Sep 2007 Posts: 141 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 141 | Hi Clutchheadscrew, Was the truck on the link that you provided painted with Rustoleum? Is there a shade of Rustoleum that is darker, more like the original paint? Thanks, Chris | | | | | Joined: Jul 2006 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 187 | Tam, thats good ole Hunter Green right out of the can with a brush! Add some black, you might get lucky. I'd reccomend a good automotive paint for repeatability. That's stew not screw although I like em' both. :whistle:
| | | | | Joined: Nov 2004 Posts: 2,409 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,409 | When I get to replacing the wood in my '41 bed, I am going use yellow pine if it's available, and paint it black. My truck will be a driver, and not a show truck. Personal preference is what it's all about. It's your truck, and you should do what you want. John
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Sep 2006 Posts: 139 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 139 | welcome mt tam trucker! i sure like that bolt of your's. it's got just the right "patina" you'll have to submit a submission to the gallery
cheers
1947 Studebaker M15 on 76 GMC one ton dually chassis with 454 4 spd 1953 Chevrolet 1/2 ton p/u 1957 Oldsmobile 88 2dr hardtop 1959 B130 International one ton dually | | | | | Joined: Jul 2007 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 70 | Hey Chris nice looking truck . as far as the bed go's i thought the orginal bed wood was yellow pine and heres another link that you may find helpful www.oldgmctrucks.com later Earl | | | | | Joined: Aug 2011 Posts: 8 New Guy | | New Guy Joined: Aug 2011 Posts: 8 | i love this truck... just plain cool
Just Drive.. no trailer queens | | |
