4 members (Hotrod Lincoln, Guitplayer, TUTS 59, IHPWR), 185 guests, and 1 robot.
Topics128,108
Posts1,056,227
Members48,436
#240201 09/03/2007 4:38 PM
So how do these things come off :confused: I have tried to get a clutchhead screwdriver and bit up there...but the angle is a little too much...I sure hope that the runningboard doesn't have to come off??????
Chuck
Blue 50
1950 3100 w/57 235
Patrick’s Saginaw 4 speed and 3:55 rear end
Sounds like you need a clutch head socket and ratchet. You say you tried a screwdriver and bit?
How about clamping that clutch head bit in a pair of vise grips at 90 degrees and see what that does.
Steve
'49 3800
'52 3600
'57 3100
Ex Hall Monitor
Ex Hall Monitor
Might be comparing apples to oranges here but the anti-squeek on my 38's running boards was riveted on and the running boards had to come off.
Are you referring to the rubber band which runs under the cab and just above the running board? If so mine were held on with small hex head machine bolts which went thru a metal strip. Accessed from underneath.
If these are not what you mean, disregard.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
if you are right olblu49 I got mine off by grinding off the heads and then grabbing hold with a pair of vise grips.
#240206 09/04/2007 12:16 PM
Yea I have tried a clutch head screw driver...can't get to them from underneath because of the runningboard. I did try the clutch head bit in my 1/4" drive ratchet but not enough room due to the same reason. I haven't tried the vice grips yet...thanks ghostrider, I'll let ya know.
Blue 50
1950 3100 w/57 235
Hey Joe,
Who, me hate clutch heads??? I love em'!! So if ya cut them off...how do ya start the new ones? The problem, is not having enough room to work with in the first place!
By the way I may be back in town this Friday....Holy Family is having a reunion all week end...if I am I'll call ya.
Blue 50
1950 3100 w/57 235
#240210 09/04/2007 11:17 PM
I must confess, I HATE those rusted on clutch head screws/bolts. I believe I have not been able to break even one loose. But I do love my Milwaukee 4.5" grinder and punch. grin
~Jim
