1 members (Hotrod Lincoln),
57
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | So how do these things come off :confused: I have tried to get a clutchhead screwdriver and bit up there...but the angle is a little too much...I sure hope that the runningboard doesn't have to come off??????
Chuck
Blue 50
1950 3100 w/57 235 Patrick’s Saginaw 4 speed and 3:55 rear end | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Sounds like you need a clutch head socket and ratchet. You say you tried a screwdriver and bit? How about clamping that clutch head bit in a pair of vise grips at 90 degrees and see what that does. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Might be comparing apples to oranges here but the anti-squeek on my 38's running boards was riveted on and the running boards had to come off.
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Are you referring to the rubber band which runs under the cab and just above the running board? If so mine were held on with small hex head machine bolts which went thru a metal strip. Accessed from underneath. If these are not what you mean, disregard. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | if you are right olblu49 I got mine off by grinding off the heads and then grabbing hold with a pair of vise grips. | | | | | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | Yea I have tried a clutch head screw driver...can't get to them from underneath because of the runningboard. I did try the clutch head bit in my 1/4" drive ratchet but not enough room due to the same reason. I haven't tried the vice grips yet...thanks ghostrider, I'll let ya know.
Blue 50
1950 3100 w/57 235 Patrick’s Saginaw 4 speed and 3:55 rear end | | | | | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | Hey Joe, Who, me hate clutch heads??? I love em'!! So if ya cut them off...how do ya start the new ones? The problem, is not having enough room to work with in the first place!
By the way I may be back in town this Friday....Holy Family is having a reunion all week end...if I am I'll call ya.
Blue 50
1950 3100 w/57 235 Patrick’s Saginaw 4 speed and 3:55 rear end | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I must confess, I HATE those rusted on clutch head screws/bolts. I believe I have not been able to break even one loose. But I do love my Milwaukee 4.5" grinder and punch.
~Jim
