2 members (crenwelge, 3800GUY),
107
Mod | | | Forums66 Topics128,283 Posts1,058,505 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 17 New Guy | | New Guy Joined: Jul 2007 Posts: 17 | Has anyone used a fuel tank out a salvage in their AD. Mounted under the bed like the '48. If so what tank fits. | | | | | Joined: Feb 2002 Posts: 2,898 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,898 | Yer tank behind the seat leaking or missing?
-W | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Most places will sell brand new tanks for about $130 bucks? LMC for one, why do you think you have to spend $500? | | | | | Joined: Jun 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 191 | jerry, s10 blazer tanks will fit at the rear of the bed. | | | | | Joined: Jun 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 191 | Or this thread had some other ideas:
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=5;t=001376 | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I just had mine cleaned and sealed at the radiator shop.
$300.
Of course, I couldn't find a repop tank that would fit under the seat, and I din't want to pull everything apart just to add a fuel cell which might not even work with the the truck's electrical system under the bed. | | | | | Joined: Jul 2007 Posts: 17 New Guy | | New Guy Joined: Jul 2007 Posts: 17 | My truck is a '54. THe tank that was in it was in bad shape. I really don't want to put it back in the cab for several reasons. Idon't like the sound of it sloshing and I really want to use that space for storage. The Blazer 2 door tank won't fit behind the rear axle because of the corvette rear end & the vette crossmember that its mounted on. What i would like to find is a poly tank similar to the one in a 2001 Blazer 4 door but slightly narrower. It would like to find a tank that would mount like the '48 beside the drive shaft inside the frame & fill from the side of the bed. Thanks for the replies. | | | | | Joined: Apr 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 275 | Originally posted by jerry d: It would like to find a tank that would mount like the '48 beside the drive shaft inside the frame & fill from the side of the bed. Thanks for the replies. Ford trucks in the '70's had tanks mounted between the frame & driveshaft. Should be a few in a wrecking yard near you. Doug | | | | | Joined: Jun 2007 Posts: 53 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 53 | try looking up some boat tanks, they make poly ones in about any confiuration you could want. Mike Bourg | | | | | Joined: Feb 2002 Posts: 2,898 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,898 | I know a guy that used one of those poly tanks on his '66 c10 here in Georgia. He said it sags when it gets warm, he wound up having to support it underneath with some metal. He told me if I ever changed mine out to use a metal tank.
-W | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | i uesd a rci fuel cell from summit 12"w x9" h x 30" fits perfect between the rear end and rear crossmember. they also come 9"x12x30 both aluminum and 15 gallon.....dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | The Blazer tank is a good inexpensive choice. With a new strap kit and lock ring from LMC, sending unit & tank from Ebay, I have less than $100 in mine.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | |
