2 members (78buckshot, IHPWR),
88
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | When is it time for a rebuild?
My truck engine (235) has probably 200,000 plus miles on it. I keep it tuned up. I’ve replaced some minor things and rebuilt the carburetor. It runs OK but I don’t drive it too far from home.
It only gets around 11mpg (city) but it doesn’t burn oil and I don’t see any leaks. The compression could be better but it always starts up every weekend. The engine seems tired after its run for an hour or so, which is understandable after 50 years.
Just wondering what others would do in this case.
Thanks. Mark | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Wow. 200K is a lot on that era of engine. Having said that, if it isn't using oil, starts & runs good and does everything you need it to do, I don't see a reason to mess with it. Your mileage isn't that bad for around town.
| | | | | Joined: May 2005 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 39 | If the compression is low or unbalanced I would start with a valve job. When you pull the head you can inspect the cylinder walls for wear and go from there. | | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I agree. I was leaning towards pulling the head. I've heard stories of some of these engines never running exactly right after a major rebuild. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Just a suggestion...I'd run a compression test first.....get a baseline reading and then add a little oil to each cylinder. A boost in compression will indicate ring wear....adding a fresh valve job will just create additional blowby.
As I see it you have three options.....leave it as it is....rebuild....or replace the engine with a decent running used engine.
A professional rebuild is going to run 2K and you know that you'll add additional bucks for upgrades.....finding a good used engine that has been replaced by a small block shouldn't be that tough in So. Cal. Or you can just drive it as it is....if it starts and runs and you just use it on the weekends it may be tough to justify the expense. Your call!
Dave | | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | Thanks Dave. I'll do some tests before I decide.
Mark | | | | | Joined: Jun 2007 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 101 | With some sweat and alittle work the rebuild kits are only at or below 900. Have fun with it. She has lasted you this long. Look into it and if a rebuild is warranted think about doing yourself. It can be complicated but the satisfaction of doing it yourself can't be beat. Good luck | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | i'd leave her alone for now, add a little of that "engine restore" it comes in 4-6-8 cylinder cans, it helped alot on my 94 chevy with 196,000 miles. 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | you can put new rings and bearins in the truck without pulling the motor drop the pan and see if the bearings are loose they make a 1000 over size i had two rods knocking once put oversize just on those two jernals and new on the rest took care of it these motores are so easy to work on if you do it your self it dosent cost much | | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | The engines that don't run right are the ones that get a shade tree overhaul. Unless you're willing to do an out-of-the-frame major rebuild, don't mess with it! Jerry
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I'd do a couple things that will make life a little easier for the old mill. Like, electronic ignition, some taller gears so it doesn't have to rev to high, maybe 30 wt oil. Plus the compression test, tune up and valve adjust. My old 47 coupe had a sweet running motor that I finally replaced but it ran great with low compression in one cylinder, drove it everywhere. Biggest help was going to 3:55 gears. | | | | | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | I got a pretty old 235 as a daily driver. This engine was rebuilt about 20 years ago, at least. All I did was a head rebuilt and new lifters 3 years ago and it runs like new again with no oil loss and 20 mpg on the freeways.
A stock 235 block if kept under 3000 rpm should last several decades, especially if not driven daily and with frequent oil changes. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Well, I don't run that well myself but hope no one decides I am too old to function. I am not old, just mature. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | It sounds like maybe you are running it a bit on the rich side if it gets 11mpg. Is your power valve working?
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I think if I commit to anything it will be pulling the head. I have two cylinders with fairly low compression in comparison to the other four.
As far as the mileage goes, my carb (Rochester B) has always functioned best a little on the rich side. I don't know if I want to rebuild it again. I may switch to the Carter YF if I can find one for the 235. | | |
