2 members (78buckshot, IHPWR), 88 guests, and 1 robot.
Topics128,024
Posts1,055,395
Members48,422
#236957 07/09/2007 10:27 PM
When is it time for a rebuild?
My truck engine (235) has probably 200,000 plus miles on it. I keep it tuned up. I’ve replaced some minor things and rebuilt the carburetor. It runs OK but I don’t drive it too far from home.
It only gets around 11mpg (city) but it doesn’t burn oil and I don’t see any leaks. The compression could be better but it always starts up every weekend. The engine seems tired after its run for an hour or so, which is understandable after 50 years.
Just wondering what others would do in this case.
Thanks.
Mark
1956 Chevy 3200, 1/2 Ton, 235 CI
https://photos.app.goo.gl/TQQo1YnFjs3U7xB57
#236958 07/09/2007 10:36 PM
Ex Hall Monitor
Ex Hall Monitor
Wow. 200K is a lot on that era of engine. Having said that, if it isn't using oil, starts & runs good and does everything you need it to do, I don't see a reason to mess with it. Your mileage isn't that bad for around town.
#236959 07/10/2007 12:46 AM
If the compression is low or unbalanced I would start with a valve job. When you pull the head you can inspect the cylinder walls for wear and go from there.
#236960 07/10/2007 12:54 AM
I agree. I was leaning towards pulling the head. I've heard stories of some of these engines never running exactly right after a major rebuild.
#236961 07/10/2007 4:16 AM
Just a suggestion...I'd run a compression test first.....get a baseline reading and then add a little oil to each cylinder. A boost in compression will indicate ring wear....adding a fresh valve job will just create additional blowby.
As I see it you have three options.....leave it as it is....rebuild....or replace the engine with a decent running used engine.
A professional rebuild is going to run 2K and you know that you'll add additional bucks for upgrades.....finding a good used engine that has been replaced by a small block shouldn't be that tough in So. Cal. Or you can just drive it as it is....if it starts and runs and you just use it on the weekends it may be tough to justify the expense. Your call!
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#236962 07/10/2007 5:23 AM
Thanks Dave. I'll do some tests before I decide.
Mark
#236963 07/10/2007 1:43 PM
With some sweat and alittle work the rebuild kits are only at or below 900. Have fun with it. She has lasted you this long. Look into it and if a rebuild is warranted think about doing yourself. It can be complicated but the satisfaction of doing it yourself can't be beat. Good luck
#236964 07/11/2007 4:57 AM
i'd leave her alone for now, add a little of that "engine restore" it comes in 4-6-8 cylinder cans, it helped alot on my 94 chevy with 196,000 miles.
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
#236965 07/11/2007 12:10 PM
you can put new rings and bearins in the truck without pulling the motor drop the pan and see if the bearings are loose they make a 1000 over size i had two rods knocking once put oversize just on those two jernals and new on the rest took care of it these motores are so easy to work on if you do it your self it dosent cost much
#236966 07/11/2007 8:36 PM
H Online: Content
The engines that don't run right are the ones that get a shade tree overhaul. Unless you're willing to do an out-of-the-frame major rebuild, don't mess with it!
#236967 07/11/2007 8:46 PM
I'd do a couple things that will make life a little easier for the old mill. Like, electronic ignition, some taller gears so it doesn't have to rev to high, maybe 30 wt oil. Plus the compression test, tune up and valve adjust.
My old 47 coupe had a sweet running motor that I finally replaced but it ran great with low compression in one cylinder, drove it everywhere. Biggest help was going to 3:55 gears.
1946 1/2-Ton Chevy
#236968 07/11/2007 8:48 PM
I got a pretty old 235 as a daily driver.
This engine was rebuilt about 20 years ago, at least.
All I did was a head rebuilt and new lifters 3 years ago and it runs like new again with no oil loss and 20 mpg on the freeways.
A stock 235 block if kept under 3000 rpm should last several decades, especially if not driven daily and with frequent oil changes.
On the road every day...
1952 Truck - 235
1948 Coupe - 261
#236969 07/11/2007 9:12 PM
Well, I don't run that well myself but hope no one decides I am too old to function. I am not old, just mature.
#236970 07/11/2007 9:32 PM
It sounds like maybe you are running it a bit on the rich side if it gets 11mpg. Is your power valve working?
Paint & Body Shop moderator
#236971 07/12/2007 3:33 AM
I think if I commit to anything it will be pulling the head. I have two cylinders with fairly low compression in comparison to the other four.
As far as the mileage goes, my carb (Rochester B) has always functioned best a little on the rich side. I don't know if I want to rebuild it again. I may switch to the Carter YF if I can find one for the 235.
