1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#236710 07/06/2007 1:49 AM
Hi All,
I'm messing with a 58 1/2 ton APACHE. I bought new front wheel bearings but have found that the hub is slightly worn and that the bearing race can move within the hub. Is there a cheap fix for this problem? I thought about applying "lock tight" or some other adhesive. Would shim stock work? As always thanks for the help.
All the best, Ted
I took mine to a machine shop where they built the area the race goes in back up then turned it to fit the new race. Has worked well for nearly ten years now. Beat trying to find another hub and it also is a 58 Chevy.
Temporarily you could take a good punch and "score" the inside of the hub to tighten up the race. I have done this many time and on many things and it served me well. Don't be afraid to put some "punch" into it with the hammer and then use one of those seal/race installer tools to keep it going in straight and I think you will be ok for sometime. Just my .02.
Its kinda like knurling a piston. Ive seen it done on a hub,,youll probably be O.K. with it. Just keep your eyes open for a hub in your travels........
The approved solution is a new hub.
The methods mentioned above will work, but should not be considered good as new.
There is a special locktite made for filling the gap between a worn housing and a race, I don't know the number right off, but this would be a semi acceptable fix.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Its called Stud and Bearing Mount....
GMC: Get More Cash...
1958 GMC
My Webshots photos
THANK YOU ALL.
I punched the hub and used the sleeve retainer locktite as suggested. It all worked out great, THANKS.
All the best, Ted
1 Offline
have you measured the wear? loctite has one called "shaft saver" i use it and it works great pre-clean area with brake cleaner and follow directions on the bottle. don't rush it! and you will be amazed.
You can save it.
Before the Loctit stuff was around, I have even seen an arc weld bead used to keep a race in place in a hub. Needless to say, the seal didn't fit well. I just used some of the sleeve & brg mount 10 micron mentioned just last week on my lawnmower's blade spindle bearing, worked slick.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
