1 members (Otto Skorzeny),
81
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 31 Apprentice | | Apprentice Joined: Oct 2006 Posts: 31 | Hello,I have a '49 3100 and I swapped the radiator out of a '47 as it was in better shape.I went to the parts store to get a 4 lb. cap and when they looked up the numbers it came back as a 0 pressure cap.I also noticed that Classic Parts offers a 0# and a 4# cap.Could someone please set me straight?By the way,its got a 235 babbit motor out of a '52.There doesn't appear to be a sealing lip in the fill neck to use a pressure cap. Confused, Chip | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Have a radiator shop swap necks for you. I would want to use the 4lb cap
Grigg | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Second that but wouldn't go over 4lbs
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | You could always run the 0# and carry a jug of water with you.
~Jim
| | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | I' go for the 0# cap and not risk the radiator whats the risk of using a little water over loosing the radiator . Afer runing a 46 chevy over 532 miles and looosing less than a quart of water throught the Bosten mountians of Arkansass the presssure cap seems usless. The old truck my buddy and I ran was put to the max of It's maximune work level and never got over 195 on the temp gauge. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I drove my 52 with a pressure cap and a 235 for 8,000 miles in june driving around the country, needed no water.... | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | 4# cap creates minimal pressure and will not damage a radiator but gives you about 12 to 14 degrees margin in case of overheating before losing water. The 4# cap is a good idea in m opinion. | | | | | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | I just put a 283 in mine and a new radiator, should i run a 4-7 lb. cap or what?...Virg | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I wouldn't use more than a 7# Virg if it's a stock style rad - works well for me w/ a 283
Bill | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Was there a 235 babbitt engine??? Hey, I run the 4lb cap on my 350 to keep from spliting the 1937 original top and bottom tank wide open! I have a new core but had the shop do as mentioned above. Changed the neck to run pressure cap. Sometimes it gets a little warm if in a parade on a real hot day but otherwise no problems. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | A low-pressure 235 was used in big trucks from 1941-1953.
I believe the Shop Manuals recommend 0 lbs pressure in small truck engines until 1953; 4 lbs in 1954/55; 7 lbs in passenger cars. I do not know about 55+ trucks/cars or medium/heavy trucks.
4 lbs should be OK, if your radiator takes a pressure cap. I have run 4 lbs in a 54 235 for years - no boil over or loss of fluid. | | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | the only cap i could for my 51, 3100 with a babbit 235 is a 7# will this be ok? ( i replacet the frozen 216 with a 48, 235) | | | | | Joined: Jul 2021 Posts: 44 'Bolter | | 'Bolter Joined: Jul 2021 Posts: 44 | I new to this numbering cap thing. My manual for 1952 1T does not show what should be used. Goofing around I looked in a classic parts catalog and it shows for the 52 to use the #0 (as previously mentioned). I’m in New England, thermostat in truck now is a 180*. Truck is Not a Dailey driver as it was a logging truck and is geared low. My top speed is like 40mph. Antifreeze has just been changed w new green also. Also adding, there are no leaks or over heating or anything, I only want to replace cap as the rubber is all cracked and worn etc. So would it be safe to say...use the #0? | | |
