6 members (3B, Shardean, TUTS 59, Joe H, Otto Skorzeny, RLB), 115 guests, and 3 robots.
Topics128,030
Posts1,055,430
Members48,422
#236178 06/23/2007 6:24 PM
Apprentice
Apprentice
Hello,I have a '49 3100 and I swapped the radiator out of a '47 as it was in better shape.I went to the parts store to get a 4 lb. cap and when they looked up the numbers it came back as a 0 pressure cap.I also noticed that Classic Parts offers a 0# and a 4# cap.Could someone please set me straight?By the way,its got a 235 babbit motor out of a '52.There doesn't appear to be a sealing lip in the fill neck to use a pressure cap. Confused, Chip
#236179 06/23/2007 6:50 PM
Have a radiator shop swap necks for you.
I would want to use the 4lb cap
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
#236180 06/24/2007 12:47 AM
Second that but wouldn't go over 4lbs
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#236181 06/24/2007 4:09 AM
You could always run the 0# and carry a jug of water with you. grin
~Jim
#236182 06/24/2007 5:15 AM
I' go for the 0# cap and not risk the radiator whats the risk of using a little water over loosing the radiator . Afer runing a 46 chevy over 532 miles and looosing less than a quart of water throught the Bosten mountians of Arkansass the presssure cap seems usless. The old truck my buddy and I ran was put to the max of It's maximune work level and never got over 195 on the temp gauge.
#236183 06/24/2007 8:03 AM
i agree with the others
1952 Chevy Shortbed
Photos in Photobucket
#236184 06/24/2007 3:45 PM
I drove my 52 with a pressure cap and a 235 for 8,000 miles in june driving around the country, needed no water....
---All pictures---
#236185 06/24/2007 5:01 PM
4# cap creates minimal pressure and will not damage a radiator but gives you about 12 to 14 degrees margin in case of overheating before losing water. The 4# cap is a good idea in m opinion.
#236186 06/24/2007 9:53 PM
V
V Offline
I just put a 283 in mine and a new radiator, should i run a 4-7 lb. cap or what?...Virg
#236187 06/24/2007 10:18 PM
I wouldn't use more than a 7# Virg if it's a stock style rad - works well for me w/ a 283
#236188 06/25/2007 2:05 AM
Was there a 235 babbitt engine??? Hey, I run the 4lb cap on my 350 to keep from spliting the 1937 original top and bottom tank wide open! I have a new core but had the shop do as mentioned above. Changed the neck to run pressure cap. Sometimes it gets a little warm if in a parade on a real hot day but otherwise no problems.
#236189 06/25/2007 2:14 AM
A low-pressure 235 was used in big trucks from 1941-1953.
I believe the Shop Manuals recommend 0 lbs pressure in small truck engines until 1953; 4 lbs in 1954/55; 7 lbs in passenger cars. I do not know about 55+ trucks/cars or medium/heavy trucks.
4 lbs should be OK, if your radiator takes a pressure cap. I have run 4 lbs in a 54 235 for years - no boil over or loss of fluid.
#236190 06/26/2007 7:24 PM
the only cap i could for my 51, 3100 with a babbit 235 is a 7# will this be ok? ( i replacet the frozen 216 with a 48, 235)
I new to this numbering cap thing. My manual for 1952 1T does not show what should be used. Goofing around I looked in a classic parts catalog and it shows for the 52 to use the #0 (as previously mentioned). I’m in New England, thermostat in truck now is a 180*. Truck is Not a Dailey driver as it was a logging truck and is geared low. My top speed is like 40mph.
Antifreeze has just been changed w new green also. Also adding, there are no leaks or over heating or anything, I only want to replace cap as the rubber is all cracked and worn etc.
So would it be safe to say...use the #0?
1952 Chevrolet 6100 2-Ton
Images in the Gallery Forum
